I don't know if this has been covered yet but, has anyone else had trouble playing finalized CD-Rs in their stock ford CD player? I have great difficulty doing this. The Maxell brand seem the worst. I have better luck with the Phillips brand. I had two other cars that played the CD-Rs fine, as did the aftermarket unit I tried in my Contour (I didn't like the fact that the illumination could not dim, it was far too bright at night). I like to stick to stock or close to stock appearance (Blaupunt or ?) to avoid the theft problem. Any help would be appreciated. Rick.
Yes this is a problem with almost everyone I've talked to and myself as well. It just seems that they do not like CD-Rs not matter what brand (for me anyway). You can try and have it sent out to be re-adjusted - but I hear that it stops working again aftert a while anyway.
You might want to try Blaupunkts different colored CD players - some match very nicely with the Contour interior. Or try the Pioneer 7100 or lower - it might not be too bad.
Sal Khan
'00 Silver SVT - KKM, SMA Torque brace.
'00.5 Aprilia RSV Mille - Renegade 2-2 Exhaust, Renegade Air Kit, lots of chips, Evoluzione Ignition Amp, 44t Rear Sprocket
Want to see what I did for lunch today? Check out http://www.mindspring.com/~salk/Lunch/LunchJournal.html !!!
Yep. I tried all brands, and the factory "premium" package wouldn't play any! Try Sony or Pioneer head units, as they both make ones that rotate closed when off, leaving a blank blck panel. It looks liek there is nothing there. I like the sony myself.
'00 Green SVT
#830/2150
K&N Drop-in
Sony X-Plod Head w/Polk Audio Spkrs
**Gone Honda Huntin'.....be back in 15.4!!
98 with Eibach Springs, Mille Miglia 17", Flowmasters. Daily driver.
_ _ _ ___________________ _ _ _
72 Datsun 510, Weber side draft, Roll Bar, 16" 300zx wheels, 300zx turbo break system. 300hp on the rear, weekend driver.
Administrator
Administrator
I have tried MANY things to get CR-R's to work in my stock CD player. The only thing I have found that works for sure, is the blue-bottom Verbatims, with a Plextor 8220 and using Nero Burning Rom. Nero also does MP3's really well too.
Chris http://crush7.dyndns.org/
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
V
V
check out nakimichi cd head units. I recommend the cd-40z or cd-45z. they are extremely low profile, simple, but have all the goodies. check out the ankimichi post for more info
1998 E0 Ford Contour SVT
Built on 8/19/97 -- #3101/6535
Silver Frost/Midnight Blue
* New Cupholders * CEG sticker =) * 9005 Philips BlueVisions * Sound System: Kenwood eXcelon KDC-X617 HU, RFosgate fnq514 components, RFosgate 6x9 3ways, RFosgate 12" sub, MTX 5ch/800w amp, 1 Farad Cap * Removed Ford emblems * Fogs w/parking lights and aimed up * Brushed Aluminum Style Grills all around * 205/55/ZR16 Bridgestone Potenza RE730's * Removed Headliner * Visit MY SVT website (UNDER CONSTRUCTION)*
i have a Pioneer DEHP6000 and i have not had any problems with CDR's. and i use TDK data disks with the blue bottom.
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t
1974.5 MG B GT
Anonymous
Unregistered
Anonymous
Unregistered
I have a sony headunit and i used to have the same problem. I found that if i used silver bottom cd's(i dont use expensive recordables I use bulk cd's I buy at a local computer show) and recorded them using the disk at one instead of track at once option with easy cd creator that this problem stopped.
email me if you have any questions.
king_nothing25@hotmail.com
Good Luck
[This message has been edited by kingnothing25 (edited August 10, 2000).]
The Alpine in-dash changer that I have in my E1 plays CD-Rs of different brands (Memorex, TDK, Imation, Maxell) including the 80-minute CD-Rs (TDK, Memorex).
Rick, if you're looking for a "stealthy" Blaupunkt that can play CD-Rs, try the Blaupunkt Houston. I installed this head unit in my Probe. It plays all of the 80-minute CD-Rs that I've made thusfar.
Reggie Wallace
'98.5 SVT (E1) - Silver Frost
#5450 out of 6135, born-on date: 4/1/1998
...I wouldn't want to bore you with my mod list :-)
I have an Eclipse head unit in my SVT, but I do notice that better quality media is less likely to skip ... so I think that probably makes it more likely that better CDR's will have a better chance of playing.
I have found the best blank CDR's to be by SONY. The actual CD is thicker than any of the others and I have never burned a coaster on them and they never skip in Eclipse ... other CDR's seem to skip (production CD's don't so it's not an install issue).
Johnny Canuck
W
W
If you're not already doing so, try recording at either 1x or 2x speed. Slow as heck I know, but this generally helps. Depending upon your equipment, the sound quality will be better, too. Yeah, I know, it's suppose to be digital so it shouldn't make a difference. But in some instances it does. To simplify the reason, when you record a CD, the recorder is constantly doing error checking while recording. Errors do occur while recording and when they do, the recorder will re-record the bad data bits. At higher recording speeds, there are more of these bad data bits which manifests themselves as apparent poor sound quality or skipping.
-Wes
98 SE Sport
Moderated by  dnewma04_dup1
