Page 2 of 2 1 2
One (hopefully) last question...
When this Oxygen Sensor is replaced, does the Check Engine Light automatically go off? Or does something special have to be done to clear the code?
Thanks!
~Anna
1998 Contour LX V6 2.5L
to my knowledge the code has to be cleared....
Black 98.5 SVT "Kellie" First rule of italian driving: What is behind you, DOESN'T matter
Just changed it this AM. Under an hour. Installed a Bosch 13115 'fat body' this time. Lets see if it lasts longer than the Ford/Borg-Warner.
Kinda sad that we're getting so good at this.
AL
Red '98 SVT E0 3098/6535 DMD other stuff and a Bullitt fuel door
Just an update, FYI...
We replaced the bank 1 upstream oxygen sensor this weekend. Put in the Bosch 13115. The procedure took a little over an hour using the wonderful directions posted in this newsgroup (to which I will post an update as we thought it would be helpful to inform anyone who may need to do this what specific tools are needed). The process involved a bit more swearing than initially thought but everything went flawlessly.
To clear the code once the new sensor was installed, I tried something that the guy at the parts store told me: disconnect the battery for about 5 min and when you reconnect it, the code will be cleared. So the CEL is no longer on!
We showed the old sensor to a friend of a friend who used to work at Ford. He informed us that we should probably have the fuel injectors cleaned as that is most likely the reason why the sensor got hot and burned. Anyone hear anything of the sorts?
Page 2 of 2 1 2
