Posts: 976 |
Originally posted by Josch: Or is it just gonna run lean and melt pistons if I want to tach redline?
That's how the kit is designed, no redline for turbo folks
Posts: 2,469 |
Originally posted by Josch: Please see the bottom of this page: http://www.ultimate-racing.com/Products/Evo8Index-US.shtml
I saw the video. please send melted clutch and tranny to 320 grapevine vista ca Impressive though.
Posts: 5,810 |
Originally posted by Josch: What does the turbo kit require to modify in order to increase the fuel or trick the computer under boost during open loop in order to get proper mixture? Do you need a different MAF caliberation or bigger injectors or eeprom chip or something of the like? Or is it just gonna run lean and melt pistons if I want to tach redline?
Chip is used to control timing and size injectors.
The mass airflow sensors on our cars reads the amount of air and if the injectors are large enough it automatically adds the correct amount of fuel. Simple enough. No fuel trickery required and thats the beauty of a MAF.
Of course if your turbo is swallowing a lot of air it may exceed the stock maf capability like mine did, then you get a bigger one and use the flow data to program the chip so the computer knows how to read it. It isn't necessary to calibrate the injectors to the maf since the computer does it all. If it knows how to read the maf signal and it knows its injector size it will add the correct amount of fuel...or close to it. Fine tuning is necessary.
See My Mods
Posts: 5,810 |
Originally posted by kinger: Originally posted by Josch: Or is it just gonna run lean and melt pistons if I want to tach redline?
Why not?
See My Mods
Posts: 9,602 |
naynay it ain't true... (go ahead and laugh the few that get that one)
I strongly suggest doing a lot of research about automobiles, forced induction, electronic engine control systems, etc before asking questions as such....
You say you have all this experience and then come back with beyond newbie questions...
{/PMS mode on hold - kind of}
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,076 |
I just watched a black one run auto X yesterday, man, when that turbo gets a chance to kick in...  Except a HIGHLY modified supercharged Camaro SS stole the show.. a friend of mine videoed his first run Clicky (watch his final lap as he gains confidence) the batteries were dead for his next 3 runs which consisted of awesome powersliding and fast times. He also taped the EVO VIII I'll see if he can convert those and host them for us.
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
Posts: 383 |
Originally posted by DemonSVT: Originally posted by Josch: Or is it just gonna run lean and melt pistons if I want to tach redline?
naynay demon maybe you need jagular to teach a thing or two about FI
98CSVT specII yada yada yada
95 Mustang GT
M&M road&track box
HP stage one
60-mm
Posts: 208 |
I saw an EVO VIII at the local track running 14.2 consistantly. Of course the track is a bit slow, but I thought for sure it would run faster than that. Probably not launching hard enough.
00 SVT Contour: SHM LT headers, LSD, Spec Stg 3...dyno:190.3whp sold 02/04
04 Subaru Baja Turbo 5-spd
00 Camaro SS 393cid: 510rwhp/469rwtq, 11.16 @ 124.95(hit 1-2 limiter)
www.erikz.org
Posts: 652 |
'95 CONTOUR SE
-Enkei 16s
-SVT wannabe
-Dual escapes w/ 2 1/2" stainless tips
-True LED taillight conversion
- Audi Xenon Projector Retrofit
-Mp3 deck, dual 10s
Posts: 652 |
Originally posted by ezsvt: I saw an EVO VIII at the local track running 14.2 consistantly. Of course the track is a bit slow, but I thought for sure it would run faster than that. Probably not launching hard enough.
Yeah, the 3" exhaust really woke that car up, along with raising the boost psi
'95 CONTOUR SE
-Enkei 16s
-SVT wannabe
-Mp3 deck, dual 10s
