New to the forum Great info!
Friday while driving to work, I noticed the Charge +/- light illuminated! Rats! About 10 minutes from work the radio went out then the a/c then I felt loss of power. No problem, I figured alternator. As I limped into the parking garage I backed into a spot and the car died.
For a few hrs of company time, I searched this forum. Great stuff! I found the tip on the mega fuse failure. I took the battery home for a charge figuring it was toast. Today went back with tools and replaced the mega fuse. When I started the car it had rough idle all of a sudden. Then when I give it gas, it really stutters and shakes like it's starving for fuel, Or bad air mix
I checked to make sure I didn't knock off any sensors, while removing the air filter parts, but nothing too obvious. The connectors on the MAF are all intact.
Drove the car home highway 23 miles and cruises ok but when I apply gas and go through the 5 gears (manual Trans) it's real harsh.
Got home and decided to change plugs.
Topped all fluids took it for a ride but no difference!
Is there a chance the PCV, 02 IAC or any other sensor might have blown also????
If I push the clutch in and rev the motor is seems like no problems but while letting the clutch out and juicing it is when it stutters and shakes
Thanks for any tips
1996 Detour Ztec
4Cyl 2.0
108,000 miles
