your atx/CD4E tranny will take Mercon/Dextron ATF Automatic Transmission Fluid. go with Mobil 1 ATF if you have the money. it is mercon compatible and works very good. by the way if you do the drain plug you will need about 4 qts but buy 5 just in case. good luck
1998 Contour V6 se ATX Black
Bassanni w/o resinators, modified intake box, DMD
New headlights w/ silverstar 9005's, blue neons inside, metal waterpump, pioneer head, pioneer 5x7
3 ways,2 10" subs, 800w amp, 17x7.5 motegi mr12 p215/45/17
