I believe these both refer to the power steering pump. I believe there is a sensor on the power steering hydraulic lines, which could be bad or disconnected. I think you need to turn the wheel during the engine running test maybe ???
thank you very much for your information...but...
i did turn the steering wheel during the test...but still getting those codes ...if it's a switch....WHERE IS IT AT??? cuz i looked around and aint see nothing
I'll check at lunch, but I believe in the V6 it is located on one of the metal tubes near the passenger side strut tower. IIRC it's a green plastic coupling with a 2 wire harness attached. (or something like that I need to go look...)
