#688822 07/11/03 02:41 PM
i got a 519 on KOEO and a 521 on KOER ....what can i do about it...? Any help will be really appreciated it
Ford Contour 1995 2.0 (140k mil.)
___________________________ '95 Contour GL 2.0L (170K) A/T
#688823 07/11/03 03:53 PM
I believe these both refer to the power steering pump. I believe there is a sensor on the power steering hydraulic lines, which could be bad or disconnected. I think you need to turn the wheel during the engine running test maybe ???
http://dalidesign.com/hbook/3digit.html
513 (O) Replace processor (PCM) (internal failure)
519 (O) PSP switch/circuit open - PSP
521 (R) Wheel not turned during test or PSP problem - PSP
522 (O) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault - PNP
Transmission MLP sensor out of range in park - Transmissions
524 Problem in low speed fuel pump circuit - Power / Fuel Pump Circuit
#688824 07/11/03 03:57 PM
thank you very much for your information...but...
i did turn the steering wheel during the test...but still getting those codes ...if it's a switch....WHERE IS IT AT??? cuz i looked around and aint see nothing
#688825 07/11/03 04:26 PM
I'll check at lunch, but I believe in the V6 it is located on one of the metal tubes near the passenger side strut tower. IIRC it's a green plastic coupling with a 2 wire harness attached. (or something like that I need to go look...)
#688826 07/11/03 06:04 PM
let me know ...
#688827 07/11/03 08:35 PM
H
H
Please read responses in your prior duplicate post: prior post
