Page 2 of 2 1 2
#688729 07/12/03 04:02 AM
I filled 3 quarts in mine.. probably came out to like 2.7 something.. with no overspill.
Black 98.5 SVT "Kellie" First rule of italian driving: What is behind you, DOESN'T matter
#688730 07/13/03 05:36 PM
klui Offline OP
Thanks for all your suggestions.
By the way, I have a friend who recommended that I changed the gasket to the tranny pan while I'm at it. What do you guys recommend? Also, our CSVT don't have a tranny fluid filter correct?!?
#688731 07/13/03 07:20 PM
There is no tranny pan or tranny pan gasket on an MTX. No trans filter on an MTX either. Your friend may have had brain fade.
#688732 07/14/03 03:39 AM
klui Offline OP
You're probably right about my friend as he had way too much to drink that night.
Thanks again, to all.
#688733 07/15/03 11:55 AM
I used the Redline MTL and it makes for super smooth shifts. I used a funnel I got at pep boys that had a hose attached to it. This worked perfectly. You can just snake it down from above and stick it in the fill hole. And both my cars just took over 2 quarts. You may want to do a search for the Redline MTL there should be a few posts on it. I think it made a big difference over mobil 1 with out the friction modifier.
Green 2000 SVT #1166 mods-K&N and Custom heat shield, optimized y pipe, Magnaflow center resonator, DMDhttp://www.geocities.com/savinoss/Cars.html -Wifes car 99 Mystique V6 5 spd
#688734 07/15/03 05:28 PM
Originally posted by SlowNfurious:
how much would a ford dealership charge for tranny fluid change ?
Too much.
Bless our servicemen & women overseas. L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
#688735 07/16/03 04:56 AM
Too much.
AMEN!!!
Page 2 of 2 1 2
