blu_fuz Offline OP
I just swapped the cluster from a svt into my '95 tour v6 mtx non-cable driven. This is what happens:
RPMs - GOOD
TEMP - GOOD
SPEEDO - Reads mileage but needle does not move.
GAS - Needle reads backwards - full means empty and vis versa
AND airbag light stays on....
So anyone trying this, here is a heads up!
EGPLNT:MY 95' SE MTX SVT *200,000 MILE CLUB* 6/06/06 - 201,000 MILES
I
I
it wouldn't be right regardless since the SVT cluster goes to 160...I think that would have some effect on it if the needle did move
blu_fuz Offline OP
Oh, I know that already.... I was just going to make little tick marks on the gauge so I knew what speed I was going if it did work...
I went up to 80 mph based on 3rd gear rpm limits and still no movement.... This is just for an fyi for anyone....
I bought el-glow gauges and took the needles off the svt gauges so I have the red/white combo - looks sharp - what gauges do you have in your tour?
no...a 98+ cluster will not work with a pre-98 car. ive tried. had the same results as you my friend.
PRIME-TOUR You're fired! I write the books here! ~Tom~
Is the PCB different or the actual speedo?? Wonder if you could just pop the speedo and all other dials out and utilise your original PCB?? I'm sure someone on here managed to do it...........
Mondeo V6 RS RS Bodykit RS Lowered SVT UIM SVT TB SVT LIM Philips 6000K HID ZENON Twin Stainless Exhaust
SVT uses different vehicle speed sensors.
Dan Acura Integra GS-R w/mods Former owner of a 95 SE
yes, a post 98 cluster will work in a pre 98 car...just not a 95. i have the full svt cluster and it works without any problems.
i've just got a set off ebay,my car is a '96,is there any danger of frying something by just plugging them in?? anything i can check prior to doing this?? thanks......
RPMs - GOOD
TEMP - GOOD
Exact same thing happened to me when I tried to install a pre-98 cluster in my 99SE. So I bought a new one (or at least a used one) for $45.00 shipped to my door from a junkyard in TN. that I found on http://www.car-parts.com
www.ChicagoCEG.com 2006 White Grand Prix
doh! I guess the only way i will know is when i plug the things in why would some cars accept a later cluster but others don't??
