Page 2 of 2 1 2
Originally posted by Eric:
Bandpass were really good, but I want to save trunk space and I think bandpass are the same size as ported boxes.
it really depends on the type of driver you use and what *kind* of bass you're looking for. in most cases the bandbass boxes will play louder, but over a smaller frequency range. the ported boxes will play fairly evenly until you hit the resonant frequency of the port and/or enclosure. then they will tend to "boom." it's a trade-off. either get evenly loud bass over a small frequency range of get sort of loud bass over a wider range with a large "bump" or "gap" in it. a sealed box will give you the tightest bass in the smallest box, but the vey low-end will start to roll off early (like around 40 or 50Hz, depending on the type of driver/amp combo).
lastly, if you're really crazy, you'll take into consideration the resonances alive in your car. for example, if i remember correctly, the gas tank will rattle more at 120Hz than at 80Hz, but overall, the car sounds "boomier" at 80Hz. so tuning a box at 80Hz will make things even more abnormal. does any one else agree?
phew!
and bazooka tubes are really not worth it, IMO.
my $0.02
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t
1974.5 MG B GT
W
W
Hey baco99 -
There is a difference in size between 5x7 and 6x8. Some speaker companies may call their speakers 5x7/6x8, but if you measure them, you'll find that they're usually 5x7. Next time you're at a car stereo store, compare the Pioneer 6x8 with anyone else's 5x7.
Also, don't assume that a 6x8 will sound better than a 5x7. If you need convincing, listen to a Pioneer 6x8 then an Infinity Kappa 5x7.
Just an FYI.
Originally posted by baco99:
5x7s and 6x8s are (usually) the same size.
WJANG:
you're right, but i did say "usually", not "always."
peace.
2001 Infiniti G20t
1974.5 MG B GT
Page 2 of 2 1 2
Moderated by  dnewma04_dup1
