Posts: 1,746 |
I'm not trying to offend anyone here, but I still haven't figured out why you need to jack the car up. In the time you spend digging the jack out, chucking the wheels and raising the car, you can have the oil changed. Its not that hard guys.
Posts: 803 |
Originally posted by Jason43: I'm not trying to offend anyone here, but I still haven't figured out why you need to jack the car up. In the time you spend digging the jack out, chucking the wheels and raising the car, you can have the oil changed. Its not that hard guys.
you must be pretty skinny to squeeze your A$$ under the car far enoough to change the oil. either that or you have really long arms
FORSALE - 17" FSVT Wheels, TRubendz catback w/magnaflow muffler PM ME
02 celica GT-S 6-spd w/ TRD bodykit
Greddy evoII exhaust, DC sports header
Injen Short ram intake, TWM short throw shifter, 18"centerline storm wheels, Tein basic coilovers
Posts: 1,746 |
Originally posted by SlowNfurious: Originally posted by Jason43: I'm not trying to offend anyone here, but I still haven't figured out why you need to jack the car up. In the time you spend digging the jack out, chucking the wheels and raising the car, you can have the oil changed. Its not that hard guys.
6'2", 210#
Posts: 803 |
Originally posted by Jason43: Originally posted by SlowNfurious: Originally posted by Jason43: I'm not trying to offend anyone here, but I still haven't figured out why you need to jack the car up. In the time you spend digging the jack out, chucking the wheels and raising the car, you can have the oil changed. Its not that hard guys.
6'2", 210#
must be the arms then
Posts: 94 |
Alright, i was thinking about saving this secret for later, as i have yet to use it to it's fullest extent... But here goes... It's called Fram Sure Drain. Poppa works for Kmart corp, and brought one of these home. Anyways Fram is in conjunction with the people at Prestone and Autolite, all of these brands i've trusted in my car, and have never let me down. Anywho, it's like $7-10. The Part # for the contour (95-00 and SVT)is SD-4, it'll be in the lower left corner of the package. So onto the explanation of the product. What you do is you change your oil at the next 3000mi interval, but, when you need to reinstall the drain plug, you instead place the "SureDRAIN Actuator Valve" into the crankcase instead. You tighten it to 20 lb/ft and make sure that the washer is int with it. You then screw the cap onto the "actuator valve". Continue filling oil accordingly. Now comes the step that i have yet to reach... When changing your oil the NEXT time, what you do is you get under the car, take off the cap from the "actuator valve" and use the "Drain Activation Assembly" which is essentially a rubber hose that will screw onto the "actuator valve" by placing the hose onto the valve and beginning to tighten the valve will slowly open, screwing on all the way will speed drain of crankcase. Make sure that the other end of the hose, is in a drain pan. Thus, no spillage on floor/hands/manifolds. I'll let you guys know how it works in another 2000 miles. But my dad used one on another one of our cars, and said that it worked perfectly. Not nessecarily like changing a duratec, but it made that job even more simple, so it should help us guys out alot. I had oil spots on the driveway the day after i did it, because i tightened the "actuator valve" by hand. After applying the proper torque with a torque wrench, no problems. If you guys got any questions, www.fram.com will surely help you out.
~Weasel Bomb
1998 Contour SE Sport
TOTALLED
For Sale:
DUAL EH'D Powdercoated Blue UIM (prefer local pickup)
Bullitt Fuel Door
Posts: 1,322 |
Secret!? That's been advertised on TV for over a year.
They work just fine, installed one on my SE sveral months (and three oil changes) ago. I modified mine a little because of a possible clearance issue. It drains a little slow, no leaks, convienant.
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 94 |
Originally posted by Marky: Secret!? That's been advertised on TV for over a year.
Well, yeah, i knew they've been around, but no one's ever mentioned them. And everyone's talking about tinfoil and all kinds of other stuff. What was the clearance issue? and how did you modify it? I wanna make sure it works on the next change.
~Weasel Bomb
TOTALLED
For Sale:
Bullitt Fuel Door
Posts: 803 |
now all they need is a invention for the oil filter so it doesnt spill everywhere except the oil pan
Posts: 2,857 |
please tell me you guys aren't also using fram filters...if so you might want to try another brand that doesn't have newspaper as the filtering media...
new,new ride!
'99 svt
black/mnb
'95 mustang gt sold!
'98 svt #800 sold!
Posts: 1,322 |
Originally posted by WeaselBomb: Originally posted by Marky: Secret!? That's been advertised on TV for over a year.
I cut off several of the barbs on the drain actuator.
I use K&N HP-2010 and 6 + quarts Moblie 1 on both cars.
