#68653 06/22/00 09:19 PM
9
9
What size are my speakers? (95 contour) Are the front and rear the same size? Is there anything unique about them? (length, width, depth, attachment, atomic modulation, gravitational pull with the Crab Nebula)
All four of mine are stock, and are starting to sound kind of funcky.
#68654 06/23/00 12:06 AM
Your speakers are 6"X8". All four are that size and in each door.
I replaced mine with 5X7 JBLs in the front and 6½" Kenwoods in the rear.
You may want to consider putting a size other than 6X8 in the back doors as I did because for some stupid reason Ford didn't line the rear grill up with the speakers! The grills on the rear doors are horizontal, but the speaker is mounted in the door at about a 45º angle. What this means is a 5X7, or 6X8 speaker would be half covered up by the door panel!
That is the reason I put a set of 6½s in the rear openings toward the bottom of the 6x8 hole. This lines the speaker up pretty well with the factory grill. I still need to get my ass to work making a panel to cover the rest of that 6x8 opening though. LOL
tdavidk
'95 SE,Duratec,MTX,all options.
GOD BLESS AMERICA!!!
Ted
tdavidk76@hotmail.com
'95 SE • DOB-4/20/95 • every option • Champagne • Duratec • MTX.
Mods: Taylor wires • Bosch +4 • Eibach/Sachs Super Gas (half done) • rear BAT urethane bushings • SVT air box (thanx Dom!) • fogs w/parks • 885 50w fog bulbs • Ray's THF • rear dome • lighted moonroof switch(thanx again Dom!) • tranny cocktail • minor stereo mods.
Yet to install: Front Eibach/Sachs • Front BAT urethane swaybar bushings.
#68655 06/23/00 03:36 PM
9
9
Thanks!
#68656 06/24/00 03:04 AM
Y
Y
Does anyone know if that is still the case with the newer models? Like my 2000.
Thanks
Larry Carrera
larry_carrera@hotmail.com
CEG Member
Chicago branch
#68657 06/24/00 03:14 AM
All Contiques (and Cougars for that matter) use 6x8s. 5x7s will work, and you can probably cram 6x9s in with some redrilling.
Louis Wang
Sugar Land, TX
1998 Black E0 #3826
http://web.wtez.net/tw57472
-Louis
1998 Black E0 #3826, lightly modded
#68658 06/25/00 06:52 PM
Anonymous
Unregistered
Anonymous
Unregistered
tdavidk
Did you have to do any extra work to get the 6 1/2s to fit? Or did they just pop in?
#68659 06/26/00 05:32 PM
i tried to fit some 6" speakers in the front and rear doors, and i couldn't get them in without messing with the metal. so, i went down to a 5.25", built a plate to block the rest of the hole and they sound great.
if you want the easiest, most brainless install, go with 5x7/6x8 speakers. generally, these sizes go hand-in-hand. the only discernable differences will be with hole patterns, but 99% of them will fit most fords. including the taurus and ranger.
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t
1974.5 MG B GT
#68660 06/26/00 05:36 PM
if you haven't done this yet, you don't know what you're missing. by not blocking the holes, you're letting a lot of valuable bass get lost via bass cancellation. and while you're at it, throw some dynamat on the door panel under the factory foam. you'll notice an even bigger difference (and a quieter ride when the stereo's not on).
[This message has been edited by baco99 (edited June 26, 2000).]
2001 Infiniti G20t
1974.5 MG B GT
#68661 06/27/00 11:13 PM
My Kenwood 6½s fit in no problem! All I had to do was drill holes.
tdavidk
Ted
Moderated by  dnewma04_dup1
