Posts: 729 |
Idom,
I have H9 projector lights.... so will this kit work for them???? Or will i have toget different bulbs????
Posts: 306 |
Markus what kind of rims are on the t-red tour?
98 CSVT Black
Alpine CDA 7995
Memphis 1000D & Alpine MRV T302
2 Orion 12's
HPP Rear Strut Bar
Posts: 1,731 |
centerline impulses I believe... they look very nice... with yoko rubber.
Black 98.5 SVT
"Kellie"
First rule of italian driving: What is behind you, DOESN'T matter
Posts: 652 |
There is some H9 info on this page: http://faq.auto.light.tripod.com/hella-90mm/ (page covers both H7 and H9 90mm and 120mm projectors)
All that came off of this page:
http://faq.auto.light.tripod.com/ (a very informative lighting FAQ page for automotive)
UNmodified OEM base D2S bulb (for factory xenon apps) WILL work in H9 projector unit as long as a few mods are made for it to fit in and be positioned correctly. This type of projector unit is one of the very few applications that will produce a near OEM result with a xenon bulb fitted into a halogen designed unit. Bulb placement IS critical to get hotspot of beam in correct location in relation to the cutoff line in the beam. All this stuff has been talked about to death on the lighting forums. Do a search on the Automotive lighting forum and you will find tons of info regarding this topic
'95 CONTOUR SE
-Enkei 16s
-SVT wannabe
-Dual escapes w/ 2 1/2" stainless tips
-True LED taillight conversion
- Audi Xenon Projector Retrofit
-Mp3 deck, dual 10s
Posts: 705 |
I doom, to ansewer your question they are H4 bulbs with a little bit of harness spliced into my stock contour harness, so I gues should get an H4 kit? pleas let me know, Thank you -Jeff-
1998 Black SVT
Morette Twin headlight conversion
Street flight turbo kit collecting dust!
Rebuilding my 3.0L
check it out
Posts: 4,760 |
Markus at this time he dosent carry the H9s sorry man.
Josch i have these on my POST 98 and theres a huge differnce. Maybe it dosent work to well with the pre98s but the POST 98s they work just fine, Yes you are correct that we wont get this nice cut off line but the lighting over stock is 10xs better.
Team Evo
Staz: You know why they call it Skunkworks?
Everyone: Why?
Staz: Because everything that comes out of it stinks!!!
Steeda-I hate you stazi
Posts: 2,529 |
Just to clarify some issues:
The kit in this GB is significantly better than the crappy stock lights. The beam pattern does produce glare, but overall lighting is improved tremendously...
There is no H9 HID kit on the market as of this moment. Markus, if you like you can slap in a true OEM D2S kit in your projectors and the results will be great....
As far as an H4 HID kit, it is also available.
Posts: 4,760 |
Jeff he does carry the H4 kit for you car, Once i get the email back from hopefully by monday i will post it up for you guys.
Thanks Milan for clarifying it better.
i would also like to note that i have had this kit on over 6months now and not once have i been flashed or highbeamd.
Team Evo
Everyone: Why?
Posts: 705 |
Sweet! I will be waiting to see when the takes place, I hope I have the money because I am defintaly interested! Thank you
-Jeff-
1998 Black SVT
Rebuilding my 3.0L
check it out
Posts: 729 |
where can i get the OEM hid kit from?????
