Posts: 648 |
Originally posted by Kremithefrog: a little less than 2".
is that it? i figured atleast 2" -2 1/4"
PRIME-TOUR
You're fired! I write the books here!
~Tom~
Posts: 3,465 |
which opening are you talkinag about the TB or what?
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 21,653 |
TB is little less than 2",,, MAF is about 3".
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 648 |
at the TB. yeah i guess that does seem right
PRIME-TOUR
~Tom~
Posts: 3,465 |
UMMM NO the TB is NOT less than 2 inches the diameter is over 65mm wich is close to 3 inches in diameter if you want I have a picture of that with a ruler showing it.
aka ZetecRacing
Posts: 21,653 |
very strange. Somehow I had a 2" coupling fitting AROUND the TB. I've seen your picture, but I've had a ruler on mine and had the coupling on.
98.5 SVT
Posts: 8,143 |
i still can't run wires through from the engine to the f*ckin cabin...either I'm just stupid or I don't have the same damn whole as everyone else.
Posts: 21,653 |
well i used a hole that on your car is filled with stuff needed for the MTX. but there are other places to go through or you just drill, or you can run under the car like some have with the cables inside a pipe.
98.5 SVT
Posts: 8,143 |
i think i'm just gonna drill...cuz the only hole i have after found has a rubber thing on the other side and I can't get it off...
Posts: 21,653 |
98.5 SVT
