Posts: 233 |
My check engine light came on, and my 96 Contour LX (V-6) just hit 85500, so I took it to the local Ford dealer for a checkup and service. I told the service advisor about a "creak" sound when I accelerate or brake, and a wheel shaking, and look into the check engine light.
The wheel shaking just means the wheel needs to be rotated and rebalanced. That's simple enough. They did that. It's fixed.
The creaking sound is something about control arm bushings... $150+ for replacement. Opted to wait on that.
The check engine light... was caused by a bad catalytic converter. Both cats are "toast", according to the service advsior. Total replacement cost... $2800?!?!?!?!!
Is this guy taking me for a "ride", or is he serious? Is there a way I can get this fixed without spending a fortune? I am only partially employed and I'm barely making my credit card payments as is.
Just a plain jane '96 LX V-6 here...
Posts: 2,319 |
Would be helpful in responding if you could post; the actual trouble codes the dealership retrieved, also whether you have experienced DPFE exhaust pressure hoses coming off.
Emissions warranty, which covers cats, is 8yrs/80,000 miles. There was also a recall on these for '95/'96 cars, so dealer should have checked if recall had been done or was still applicable.
The pre-cats are in each of the exhaust manifolds and then there is the main cat under car. Replacement of all of them would be in the $2,000+ range you quote.
Alternate solution wouild be to gut the pre-cats and replace only main cat but you would first have to research how that would affect passing your State's emissions tests.
Posts: 1,044 |
My 95 suffered from this problem, but the insides of the pre-cats began crumbling and caused the main cat to become clogged. There are few sources to get pre-cats so your stuck with dealer pricing on them and there is lot of labor to replace these. A replacement main cat is available from many sources and a 'universal fit' will work fine. If the pre-cats are bad, gutting them is a lot cheaper than replacement. If the main cat is working well, you should pass an emissions test.
Posts: 233 |
Originally posted by horseydug: Would be helpful in responding if you could post; the actual trouble codes the dealership retrieved, also whether you have experienced DPFE exhaust pressure hoses coming off.
They didn't give me the trouble codes. :P All it says on the report they gave me is "Tested Cat. Cat efficiency low."
And no, no pressure hose coming off.
Recall was already done. This car has been under dealer care since purchase...
Eeek. I can just see the labor pile up on that one... But I guess my question is WHICH cat needs to be replaced, right? I mean, it's normal for the dealer to tell me "all of them", which I only want SOME of them?
This is California... Unlikely, esp. with the new SMOG2 coming online soon, but one can hope...
So most of that is just labor, right?
Posts: 3,037 |
I got my main cat replaced at a total expenditure of about $250. Found the actual part online for $100 or so and got my local shop to install because my Contour buddies around here were tied up. The precats are a lot more complicated, sure, but IMO since you're not getting the work done under warranty, I'd say screw "dealer care" since I rather doubt they care much about giving YOU the best deal. Shop around.
Posts: 667 |
You can also DIY for a lot less. Check the following sites for cats: http://www.all-catalytic-converters.com/ford-contour-converter.htmlhttp://www.catalyticonverters.com/ford_contour_catalytic_converter.htmlI'm sure there are a lot of other places that sell cats cheap as well. According to those sites, if you replaced ALL of the cats, then it would run you about $1300. Replacing one or two would be a lot less. You can also read the following tech articles to try and determine which cats are bad: http://www.all-catalytic-converters.com/techtips.htmlhttp://www.howstuffworks.com/catalytic-converter.htm
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
Posts: 7,117 |
'Scuse me, but would this be a good time for him to consider a Brullen or other Y pipe with a cat? Would this not solve his cat problem, give more performance, maintain emissions standards, & cost way under $1000 INSTALLED? Please correct me if I'm wrong.
Posts: 70 |
Originally posted by TourDeForce: 'Scuse me, but would this be a good time for him to consider a Brullen or other Y pipe with a cat? Would this not solve his cat problem, give more performance, maintain emissions standards, & cost way under $1000 INSTALLED?
thats what I was thinking, just get an aftermarket y-pipe. I havent checked but how much can this y-pipe cost
95 Contour Gl - the work beater - bought 6/15/03
88 S-10 Blazer - back up beater - owned since 89
97 Cobra Vert - my weekend toy - bought 12/01
Posts: 7,117 |
Brullen Y is $335 with a cat. I figure that much for the install & the shop will probably break a few bolts (his car is a 1996) & charge him for the extra labor.
I figure $800 plus any taxes. I am assuming that this will fly with the emissions standards in CA, but they are notorious tight-asses there.
If it won't fly, pick up a Y pipe setup from a bone yard, pass emissions with that, then buy the pipe you want. Still WAY cheaper.
Posts: 1,788 |
Aftermarket Y-pipes do not contain the precats and will not resolve the original poster's dilema.
Precats are over $500 each and I have yet to find an aftermarket source for them for the Contour V-6.
My guess is that the codes the dealer pulled were P0420 and/or P0430. There is no sensor after the Y-pipe cat, so it is never checked by the engine's computer for efficiency of operation.
Bummer. Too bad that your car waited until your 8/80 warranty expired.
My suggestion would be to order the pre-cats/exhaust manifolds from a discount Ford parts distributor, then hire a local shop to replace them at the flate rate times.
You can then get an aftermarket y-pipe with its cat to complete the job. Total cost should be around 60% of your oringinal quote.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
