#682029 07/03/03 12:58 PM
I've tried searching, but kept coming up with no matches for everything I could think of. What is involved with removing the MTX75 from a Zetec car? Does the engine/trans have to come down as an assembly, or can the transmission be pulled with the engine in place? If I where to drop the entire engine/trans/subframe, how difficult is it do? There's one in a U-Pull-It yard that I'm considering attempting to get, but I want to know what I'm getting into before doing so. Any help would be appreciated...
Rick Barnes '66 Ford Ranchero '84 Ford EXP Turbo Coupe '88 Mazda 323 GTX '88 Mazda 323 SE/GT hybrid '93 Ford Aerostar XLT AWD '99 Ford Contour SVT
#682030 07/03/03 03:32 PM
Order a Ford Service CD from me. It will tell you everything.
#682031 07/03/03 05:18 PM
It's a 10+ hour job!
Supposedly alot like pulling one off a Duratec.
Maybe 1-2 hours less time.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST Pre98 Zetec - Some Mods
#682032 07/03/03 07:07 PM
O
O
screw the ford service CD. it's less of a pain to pull everything out from the top than to drop the subframe.
disconnect coolant lines, disconnect all electrical, remove the a/c compressor from the block, remove the ypipe, disconnect the engine mounts, and pull it all out.
~nick 2001 Cougar V6 MTX 3L Cougar.
#682033 07/05/03 03:40 AM
the ford service cd tells you how to take everything out of the top.
I bought it and i love it.
Matt '99 SVT Contour ---------------
#682034 07/05/03 06:39 AM
O
O
you sure on that?
both my ford cd's (99 and 2000) give instructions on attacking it from the bottom.
#682035 07/05/03 12:23 PM
Factory manual is "out the bottom".
#682036 07/05/03 02:29 PM
i never looked at a zetec, but for a duratec the cd has you drop the subframe, while using a special brace to hold the engine from falling out, and take the tranny out from underneath
Russell Oval Port 3L Nearly Done MTX75 w/ Homebrew Zetec FD and Torsen Complete
#682037 07/05/03 03:05 PM
U
U
Buckshot stated awhile back that he did his through the top. Even though it was a Duratec, it should not matter. Basically, he pulled the engine, leaving the tranny in place then removed the tranny. He stated at a time of about three hours IIRC, but that is with plenty of experience. You will not be able to pull them both out at the sametime!
The CD does state that the tranny should be removed from the bottom by way of supporting the engine with a brace, unbolt all mounts and connections relavent to what you are removing, drop the subframe and while supporting the tranny with a transmission jack you lower the tranny out of the engine bay.
If you just look under the hood long enough, you will be able to see how both methods would work.
And not trying to sound like a salesmen or anything, that Service CD can give a whole lot more insight into jobs like this, rather just instructions. Get the CD, look over the procedure then go look at the car. I am sure will could find some steps that you would do differently. It's only a few bucks, so what would it hurt?
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
#682038 07/05/03 03:30 PM
Not that it has a lot to do with the contour, but, I had an old Tempo (for ten years 189K mi and two clutches) that I had pulled the tranny 3 times and the motor once. The shop manual says to take it out from the bottom, when the dealer replaced the motor under warrantee thatā??s what they did. However when I pulled the motor and/or tranny I did it from the top. I think the service manual assumes you have a lift so they work from the bottom. Working from the bottom prevents the engine/tranny from swinging into fenders and AC condensers (I think thatā??s another dealer consideration.
I see no reason the Duratec and tranny canā??t come out from the top, but you need a good hoist (donā??t use a come-along on a tree).
jeff
have you fixed your ford lately?
