Thanks guy.
BigJim, you confirmed one thing I was thinking. That was if it was flooded.
One of the things I found was that the spark plug boots did not seem snapped on all the way on the of the cylinders. This made me start on the path of thinking the 3 plugs got fouled from poor spark. But that did not explain why the other 3 did not fire at all.Not even a sputter.
I fear that it might be a head gasket also after skimming through the archives. The car has 58,000 on it and I saw signs of coolant on the outside of the radiator making me think it has overheated. Seeing the stuff about the waterpump impellers breaking makes me think this is the case.
Playing with turbo cars for the last 8-9 years, I know all about headgaskets
and I would think it should still at least have a sputter of life even if one whole bank of cylinders had the gasket blow between all of them.
I think tommarrow I will verify fuel pressure. Then either max charge the battery or buy a new one. Also might throw some plugs and wires at it. At that mileage I wouldnt think it would need them, but the front left one's boot (#?) was pretty rotted and came apart very easy.
If all else fails, I will throw another motor in there. I do have a line on a cheap SVT motor , but I might have missed it , so a stock replacment would have to do.
I was hoping it would be easier to run the codes like my earlier cars
