Page 2 of 2 1 2
Mitch Offline OP
Banned Again
Banned Again
Yeah its shiny " i will NEVER" have to use armor all or anything in that nature again ! but no windshield glare .
Not sure hot the HOT sun would deal with a black dash ,but i wouldnt hesitate man , black is VERY EASY to deal with .
Didnt clearcoat it .
I
I
damn thats a good cheap way of changing the interior...looks like a shitload of work though
Mitch Offline OP
Banned Again
Banned Again
NO heck i did it in a few days , but then i didnt just do the dashboard , i did the COMPLETE car with all panels.
CEG road warrior
CEG road warrior
That is nice. I am not for that much work...right now. I am running out of stuff to paint.
Nice job, Mitch.
But don't you think it would look better like this ?
'01 GTP: 3.3" pulley, Headers, 3" Exhaust, Straight Pipe, Intense Air to Water Intercooler.Pictures Old Ride: 95 Mystique LS V6 ATX: Pictures
Originally posted by Tim:
Nice job, Mitch.
now thier is a mod for that frog guy
97 Mystquie GS - I4 ATX died at 168K 94 Pontiac Crap AM SE - 2.3L I4 5spd 2002 Mazda Protege5 - 2.0L ATX
Mitch Offline OP
Banned Again
Banned Again
how do you do that with adobe ?
Whomever said that I did that with Adobe ? I went to your house, busted into your car, got some nice green paint, applied it, let it dry, polished it on nice and shiney, took the picture, then used some nail polish remover to wipe it off, all in the span of 20 minutes!
All thick and obvious sarcasm aside, things like this are really easy to do in Adobe--it just takes some patience with the lasso tool.
Use your polyon or magnetic lasso tool to form an outline around the area you want to apply a color change to. You just want to get the overall outline, so don't worry too much about the inner pieces that you don't want blobbed over, as you can go back later with an eraser tool and clear those out if need be.
Once you have an area selected and polygonned off, right click and select "Layer via copy." If you choose "Layer via cut," usually you'll get an ugly outline around the area you cut, and you don't want that. I like using copy because it simply hides the area underneath meaning I can, of course, go back later and make changes if I need to.
Next, making sure you have the layer you want to make a color change to selected, goto Adjustments -> Hue/Saturation. Select "Colorize" and "Preview" (enabled by Default) from the bottom checkbox area. Move the Hue, Saturation, and Luminosity sliders around to change the color of the areas you want to be a different color. If your ultimate goal is simply to grayscale, I might suggest you simply use Adjustments -> Desaturate.
Go back on the copied layer and use your eraser brush tool to clear out any areas you don't want changed. Easy as pie, aye ?
Cheers,
Tim
BTW, apologies to all of the skilled photochoppers out there if I gave away any trade secrets Knowledge shouldn't be withheld!
Tim
Page 2 of 2 1 2
