Page 2 of 2 1 2
#677508 06/30/03 02:32 AM
That's a solid time indeed. What was your estimated trap speed? I'm sure you looked at the speedo when you were crossing the line, right?
Derek Scion xB 5-spd Previous: 2000 Silver Frost SVT Please share the road with cyclists.
#677509 06/30/03 04:41 AM
9
Hah, yeah, I was foolin' around with you SeRguy.
#677510 06/30/03 05:28 PM
Haha no harm, I figure I was in the 96 mph area it looked like. I had my eyes glued to the tach and was just worrying on banging through the gears quick and smooth. I ran against a freaking Mavrick with a 289 6 cyl, he swears all he had were cams and exhaust and changed his gearing, put down a 14.1 and the last race I ran against a Roadrunner, he put down a 14.4. Never went against an import car myself. One thing I need to work on is reaction time, I was more worried about launching than reaction, next time I will work on that
Also I will be taking the Daytona down next time, hoping for low 13's
Ryan
2004 WRX STI 91 Eclispe GSX (to many mods to list, Want to race?)
#677511 06/30/03 08:14 PM
No 289 cu in 6. Ford made the 289 V8 that went into everything. Was the father to the 302. Same block essentially. I'm calling BS on that guy having a V6.
#677512 07/01/03 01:11 AM
Coulda been a 300 straight six - good torque!
Now owner of 0 SVT's. my web page
#677513 07/06/03 10:13 PM
Seems like a 300ci I6 would be a tight fit into a Maverick. Isn't is longer than the 200ci I6? I think that engine just fit length wise.
Probably a 289 V8
TB
"Seems like our society is more interested in turning each successive generation into cookie-cutter wankers than anything else." -- Jato 8/24/2004
#677514 07/07/03 05:10 AM
O
O
Best N/A guy is running 13.1 (Edo, he is the shiz)
"AEM CAI - Hondata K20A derivitive reflash - Hondata intake gasket - K20A intake manifold 64.8mm port matched - 70mm taper to 64.8mm bored TB - Comptech Race Header - ES motor mount inserts - JIC Carbon Fiber rear strut tower brace - JIC FLT-A2 - neg. 2.6 camber w 1/8" toe out (corner weighted & balanced 50/50) - Specialty Products Rear camber arms - 2.25 neg. Zero toe - K20A Final Drive - UR SS pulley set - Motul synthetics: Tranny & Motor Oil - 5zigen Fire Titanium Catback Exhaust - D3 Designs Front strut tower brace and lower x-brace - Revo SS and Capyoda bushings - ES front/rear control arm bushing set - Rotora Big Brake Kit - Axxis Ultimates rear brake pads - ATE Super Blue brake fluid - 5zigen FN01-R - Azenis 225/45/17 - Hyperground Universal kit - Ignition Solutions Plasma Direct Coils - Factory front sway with Energy Suspension urethane bushings - Hotchkis Adjustable rear sway bar, competition endlinks - SealsIt Rod End seals 3/8" (16 total) - Bogart Drag Wheels 15 x 8(Front) 15 x 4(Rear) - M&H Racemaster Drag Slicks and skinnies 23 x 8(Front) - 24 x 3.6(Rear) - Toda valve springs - Ti retainers - 12100-PRB-A00 - competition headwork with 36mm (+1mm over stock) IN stainless valves, Toda Spec A cams - ATS 1600kg Carbon clutch and Flywheel package - Driveshaft Shop extreme level 5 axle/hub system - OS Giken Superlock LSD "
DAMMMMMMMMMMMMNNNNNNNNNNNNN EDO is the SHIZ...
MY NEW HOBBY...RUINING CHRIS CROFTS LIFE...
#677515 07/07/03 01:01 PM
W
W
Sounds really good! It isn't your average fat-pig street car like mine is though.
warmonger
#677516 07/07/03 05:06 PM
9
I'm going to guestimate that there is over $10k in mods right there. Does anyone know for sure? That dude has a lot of money in that car.
95 SE Modded - Gone 98 E0 Black SVT - Gone 98 se sport - Broken 00 T-Red SVT - Nice
#677517 07/08/03 01:51 AM
yawn.....
Page 2 of 2 1 2
Moderated by  mbb41_dup1
