Posts: 21 |
Hi, I got the codes: P0153 and P1151, And they are from the B2 S1 sensor, they want to charge me 200 to change it!!, could you tell me where is located thi sensor?, and could I change it myself? Any special tool?
Tanks guys,
1998 Contour V6 2.5L ATX
Posts: 237 |
P0153=Upstream Heated Oxygen Sensor (HO2S 21) circuit slow response (Bank #2).
P1151=Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, sensor indicates lean (Bank #2).
B2 must be bank #2.
1996 Contour SE Sedan 4D (Royal Blue) Duratec V6 2.5L 24-valve DOHC Automatic 75,000 miles No Mods (unless you call the DMD a mod) Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
Posts: 21 |
I suppoused it was from bank 2, I just have the doubt of where in the car is the bank 2, I know that there are 4 sensors, and I do not want to replace one that is working fine, Additionally, Are the three sensor the same?, If I bought it I just buy an oxygen sensor for contour 98 duratec? or OD I have to specify which one?
TNX
Posts: 237 |
Originally posted by ramon1809: I suppoused it was from bank 2, I just have the doubt of where in the car is the bank 2, I know that there are 4 sensors, and I do not want to replace one that is working fine... The following is from http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=3;t=006069 Last but not least, it is worth noting there are actually four sensors: upstream and downstream for each of the two cylinder banks. They are called HO2Sxy, where x indicated the cylinder bank number (bank 1 is closer to the firewall), and y indicates upstream (1) or downstream (2). HO2S11 seems to be the most frequently-mentioned of them all (I replaced mine last year; there's a wealth of info available via Search).
Additionally, Are the three sensor the same?, If I bought it I just buy an oxygen sensor for contour 98 duratec? or do I have to specify which one? I believe that the front two sensors are a little different than the back two. I got the following from http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=3&t=008139&p= To make sure you've got the right O2 sensor before you leave the store, the lower one's have a round connector and the upper is a sqaure connector. You can go to http://www.boschusa.com/AutoParts/PartFinder/PartFinder.asp for info on Bosch oxygen sensors.
Posts: 1,040 |
Originally posted by G Pappas: ..I believe that the front two sensors are a little different than the back two.
Perhaps ambiguous. Upstream (front) are before catalytic in manifold, downstream (back) are after catalytic in manifold. The sensor of concern is on the exhaust manifold behind rad and to the right of oil filter. It is possible to change without an O2 sensor socket by using an open end wrench.
Posts: 21 |
How much should I paid for this sensor, ( I saw one in $67 in napaonline) Souhld it be motorcraft, bosh, is it the same use any brand? Can I replace the sensor from the top?, or do I need a ramp?
TNX
Posts: 21 |
Originally posted by ramon1809: How much should I paid for this sensor, ( I saw one in $67 in napaonline) Souhld it be motorcraft, bosh, is it the same use any brand? Can I replace the sensor from the top?, or do I need a ramp?
TNX Any Picture of the location of the sensor??
Posts: 21 |
Originally posted by ramon1809: Originally posted by ramon1809: [b]How much should I paid for this sensor, ( I saw one in $67 in napaonline) Souhld it be motorcraft, bosh, is it the same use any brand? Can I replace the sensor from the top?, or do I need a ramp?
TNX Any Picture of the location of the sensor??[/b]Any one??? please
Posts: 237 |
Originally posted by ramon1809: How much should I paid for this sensor, ( I saw one in $67 in napaonline)? I believe that you can find them for ~ $50-60 at the low end.
Posts: 21 |
Originally posted by ramon1809: Originally posted by ramon1809: [b]Should it be motorcraft, bosh, is it the same use any brand? Can I replace the sensor from the top?, or do I need a ramp?
TNX Any Picture of the location of the sensor??[/b]TNx, and what about a picture?, can I replace without a ramp?
