Page 1 of 3 1 2 3
chongo Offline OP
Well those that are about to do this I salute you!
Be prepared for anything!
I picked up my Turbine sensor today and thought what the hell I can do this
this afternoon no problem it should take 45 minutes.
NO PROBLEM my a$$!
That thing wouldn't budge I used 1 can of liquid wrench! (yup 1 can).
Started off thinking I could do it with the wheel on, I tried couldn't budge it, so pulled the wheel off.
Still couldn't budge it!
So I get out the mini crowbar to break the seal a little, it was working great!
Got my neighbour to grab the vise grips while I gently use the crowbar on the seal (we are an hour into this so far)
an what happens SNAP!!!!!!!!!
Damn thing shattered and went straight in with nothing to pull from to get it out.
I spend the next 2.5 hours drilling, chipping, pulling....etc
Finally at the 4 hour mark! (yup 4 hours) it slides out like butter!!!!!
Damn thing has a magnet in it that sucks it back in everytime you get it close to getting it out...
My magnet finally broke off and with 3 different sets of needle nose it finally came out!!!!!
It took 10 minutes to put in new sensor, but took 4 hours to get it out!
So all I will say is GOOD LUCK, clear your whole day and be very patient!!!
Was it worth it, damn I don't know let me drive somewhere first!!!!!!
1996 2.5LT V6 Contour ATX My Tour+help/info pics E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
I am Canuckian
I am Canuckian
Well that is not too encouraging since I'll be helping do Keith's tomorrow. I would like to get other things done tomorrow as well. Better not take 4 hours.
Beyond all the meyhem what are your inital thoughts on this mod?
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
H
H
Previous installer probably forgot the petroleum jelly.
Turbine Shaft Speed (TSS) Sensor
Removal
1. Raise and support the vehicle. For additional information, refer to «Section 100-02».
2. Place a drain pan beneath the turbine shaft speed (TSS) sensor.
3. Remove the TSS sensor.
-Disconnect the TSS sensor electrical connector.
-Remove the bolt.
-Inspect the TSS sensor bore.
4. Inspect the O - ring seal for nicks or cuts; install a new as necessary.
Installation
Note:
Apply a light coat of petroleum jelly to the O - ring seal before installation.
1. Install the TSS sensor.
-Connect the TSS electrical connector.
2. Remove the drain pan.
3. Lower the vehicle.
4. Check the transmission fluid level, add Motorcraft MERCON® Multi - purpose automatic transmission fluid or equivalent meeting MERCON ® specification as necessary.
5. Start the engine and move the transaxle range selector lever through all gear positions.
I am Canuckian
I am Canuckian
Thanks Horseydug, that'll come in handy.
chongo Offline OP
LMAO!!
horseydug I thought it was gonna be that easy too!
BTW nothing comes out the hole no need for a pan!
Just plastic shards from drilling!
Well Mark as much as I hated what happened to me, in my drunk'n state
right now man I can't believe I'm typing this I will be there..........
I must be otta my mind to go through this again...
Thanks Jeff. You've scared Mark now.... he prolly doesn't even wanna do it.. oh well. he has no choice. if he doesn't I'll use my tart-a-rang on him!
97 T-Red LX ATX pre98 CF SVT front,SVT rear/side skirts FSVT wheels Custom Front Ford Logo (body Colour) 35% tint all around with sun visor WP With Metal Impeller? Elky Grills CTA Intake CTA Custom Dual Exhaust
I am Canuckian
I am Canuckian
Noooo not the Tart-arang......please I don't think I could take it. Too sticky and all.
H
H
Originally posted by chongo:
... BTW nothing comes out the hole no need for a pan! ...
I didn't think so either, but just quoted '98 service CD verbatim.
Guys maybe my mind is not working well today ... but what does the TSS do? Did you get a better one or did yours fail. I guess I'm just confused!
95 Contour GL 2.5L ATX Minor mods
The turbine speed sensor controls the shift points in the tranny. Replacing the TSS with an updated sensor eliminates the 1-2 bang in an auto tranny. If you let off the gas under hard acceleration just as the tranny want's to shift from 1 to 2 you will induce a large bang and hard shift.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
Page 1 of 3 1 2 3
Moderated by  Gerald_dup1, mbb41_dup1
