#67633 08/02/02 03:34 AM
I just found out why the brake warning light started to come on. There's a leak on the brake line going to the rear brakes! It dripps so bad that my floor slowly sink to the floor, and leaves a puddle! Where can I find lines to fix this?!
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
#67634 08/02/02 06:38 AM
I think NAPA can custom order you a line for your make/model of car. Probably cheaper/faster than a dealer, but dealer may be your only choice.
Scott
#67635 08/02/02 12:14 PM
If they can't custom order the line, take the old line in and ask them to bend you a new one.
Most parts stores have brake line stock and they can bend the line with a tube bender.
If the leak is right at the flare where it connects to the master cylinder, and there is enough slack, you MIGHT be able to cut off the end and reflare the line.
But a new line is best.
TB
Tony Boner
#67636 08/02/02 03:20 PM
If the leak is right at the flare where it connects to the master cylinder, and there is enough slack, you [b]MIGHT
TB[/b]
You can flare your own, but bear in mind the flare is a double flare, not single. You need a special tool for this....
"My Name is Richard. I am a Contouraholic."
1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades;
Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod;
PIAA 9006 Super White Headlamps
AIWA CDC-MP3 HU; WeatherTech Mats
Viper 600ESP w/Remote entry
#67637 08/02/02 11:53 PM
What size is the brake line? I went to Advanced Auto Parts and they said there are different sizes, and the union I need to connect the lines (splicing in a new section) comes in different sizes too.
Car Pics
#67638 08/03/02 12:20 AM
I dunno the size, but if they have a replacement master cylinder they can test fit lines from the straight stock lines until they get the right one.
Short of you coming in with the line in your hand, this might be the best alternative.
TB
Tony Boner
#67639 08/03/02 12:50 AM
OK, I just checked with the FSM and it doesn't say what size the lines are. They only show a few diagrams of the unions. But that doesn't help neither... They showed both ISO and SAE style. It's so confusing. Maybe I should just duct tape it! LOL
[EDIT] I just read this page - http://volksweb.relitech.com/brakeln.htm . That guy mentioned something about using compression fittings at the union instead of making the flare. I think it'd work because that's what I have on my mountain bike (yes, I have hydraulic brakes on my bike) and they have the same style compression fittings. They hold up very good, no leak. I'd assume it's better than buying a special tool for the double flare, and better than replacing the whole line.
Car Pics
#67640 08/03/02 01:32 PM
All the unions are metric as is the tube.Never use compression fittings on brake lines,they are fine for trailer type brakes but not on a vehicle.Get the correct tube/hose.....dont 'mess' with brakes...its your life we are talking about here!
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#67641 08/04/02 04:34 AM
Never use compression fittings on brake lines, dont 'mess' with brakes...its your life we are talking about here!
...and the lives of everyone else on the roads too!!!
2000 SVT #674 - Check it out!
#67642 08/04/02 01:36 PM
Thats good to know. I have the tooling to make 45' flared ends in tubing but it can not accomodate metric tubing.
For just one line, I'm sure it would be less expensive and less troublesome to buy a replacement line than it would be to buy the tools and fabricate a segment of brake line to replace the section that is leaking.
"careful man, there's a beverage here."
e-mail: boseraq@hotmail.com
aol IM: madhat1412
