#67611 08/02/02 02:04 AM
Mufka Offline OP
I've had the Check Engine Light on on my 99 SE for about a week. I had it checked at Auto Zone and they gave me the codes P1131 and P0133. He said it is the O2 sensor in bank 1. Where is bank 1 and is it easy to replace?
Thanks
#67612 08/02/02 02:53 AM
Your Duratec has two O2 sensors on each bank. The first set is on the exhaust manifolds before the converters, the second is downstream in the exhaust. Bank 1 is against the firewall. It's not an easy job. Some people can replace from top after components are removed, others get it from below or I think, through the wheel well. A special socket is required. You may want to have an experienced mechanic do it.
Al
#67613 08/02/02 02:36 PM
For the 2.5L V6: the rear upper sensor is not THAT hard to replace. Bank 1 is the rear bank, and P1131 means the upper sensor, before the cat. The rear upper 02 sensor is definitely the hardest of all 4 sensors to replace but it is doable. Having wrists that aren't fat helps smile .
I worked from above and below to get access to that little bugger. There is no need to get in through the wheel well. As a matter of fact, going in through the wheel well will never get you near the sensor.
Anyway, when I did mine, I used the following tools:
misc sockets to remove coil packs
7/8" combo wrench (box end + open end)
Liquid wrench to loosen old sensor
There is a special 02 sensor socket out there but I did not use it.
That's all that comes to mind right now, but there may have been other standard tools used along the way.
For detailed instructions, do a search on '02 sensor replacement'. Someone out there wrote a detailed guide....
-Kurt
"I'm a little sceptical of that internet thing. After all, what's it got besides information?"
-DB, 1/97
#67614 08/02/02 06:33 PM
Yup, the sensor is hard to get at, but not impossible. I found it easiest to lay a flattend out box on the UIM so I had a place to neel down on top of the engine. A flashlight, a 3/8" breaker bar, and an O2 socket did the trick. IIRC there is a fuse/link or big wire down in that area that likes to get in the way. mad
Scott
#67615 08/03/02 12:55 AM
My experience with this , for what it's worth. laugh
Garrick
Silver E0, #3895 of 6535, built 10/2/97
She's stock. Why mess with a good thing? laugh
