Posts: 2,483 |
1st gear sucks so bad on my car.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 2,094 |
Originally posted by LoCoZ2: Originally posted by fingas: Originally posted by Dan Nixon: The 4-5 HP & torque seen by Ford Racing is pretty typical for UDPs.
First gear is where i feel i need the most help.
Not me. I need help in 2nd gear!
Will the cam gears help you in 2nd any? Also, does the car need to be customed tuned to give the 9hp in 2nd for the UDP? Or is that an automatic gain when you add the UDP?
'95 GL White
I've got mods.
Posts: 2,483 |
Cam gears "seemed" to have helped me down low. As I haven't dyno tuned them yet, I can't say for sure. No tuning necessary for UDP, just need the correct belt.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by SleeperZ: Cam gears "seemed" to have helped me down low. As I haven't dyno tuned them yet, I can't say for sure. No tuning necessary for UDP, just need the correct belt.
Exactly what I need!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 682 |
Originally posted by ZetecRacing: then WHY does a lighter fly wheel on a MTX do that???? it's the same diameter just lighter and it caused gains in the quarter. same princapal as the UDP just on the other end of the crank. the reduction in diameter desn't cause it to free up as much as the lighter weight does.
Because that's like a ten pound difference instead of a one pound difference. A stock crank pulley weighs 3.4 pounds (your UDP does not save six pounds) and has a radius of about 2.5 inches. A stock tranny flywheel weighs over 20 lbs and has more than twice the radius, and probably has more of its mass concentrated at the outer edge. That means that it has something like fifteen times the moment of inertia that the pulley has.
Posts: 21,653 |
My UDP, I'll let you know how it is after I "test" it.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Kremithefrog: My UDP, I'll let you know how it is after I "test" it.
Huh?
Hector
257HP/259TQ
160HP/141TQ
Posts: 21,653 |
Get to stomp on pedal really hard w/o all my tools and old parts in the car. a.k.a. butt dyno
98.5 SVT
