Posts: 21,653 |
better yet, just badge it as some honda type-r Si TRD mungen that you imported.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 5,810 |
NOt a bad Idea, but I emailed the fools in charge of the track and they basically said all Jap car names. I hate it when people just can't think out of the box.  The perfect example is at Whataburger the other day: I wanted their new oreo cookie shake, but I also wanted their new Butterfinger flavored shake. Big Dilemma!  I also like them mixed, then I get the best of both worlds!  So I said, can you mix it for me. The lady said no, we can't do that.  I said, just use a half scoop from one and a half scoop from the other, then you aren't giving any away. She said, No, we can't do that sir. (She's the shift manager too!)  I made some comment about it's easy, take the scoop measure half, etc. then I grumbled a bit, ordered the Oreo flavored shake and sat down to wait. When my wife came in to meet me, I grumbled Loudly about narrow-mindedness. Nothing like good customer service to keep you coming back eh? The cool thing is when the young kid who was working behind the counter brought the shake he said, Don't worry about it sir, I made the shake and I just threw another scoop in and mixed it for you. I was thinking, Right On Dude! End of story.
See My Mods
Posts: 51 |
800 sounds really good for such a intercooler kit produced in such low volume. I paid that much for my Greedy, I mean Greddy intercooler, and I got a deal!
Peter
98 MTX V6 SE Sport
05 RSX-S
and a Turbo MR2
Posts: 682 |
$800? It sounds soooo much cheaper to just add two more pounds of boost instead...  Okay I have another question. If one is going to lower one's compression ratio with a thick head gasket, is there a selection of thicknesses available so you can pick how much you want to lower it? Who sells them? Presumably lowering the CR would solve the detonation problem, no?
Posts: 165 |
Originally posted by Paul Kienitz: $800? It sounds soooo much cheaper to just add two more pounds of boost instead...
Boost (and power) cost money. It depends on how long you want your engine to last. An intercooler will help your engine last longer, and let you run more boost. Is it necessary? No, but it gives you a saftey window. The cheapest Zetec I've found around here is $600.
Originally posted by Paul Kienitz: Okay I have another question. If one is going to lower one's compression ratio with a thick head gasket, is there a selection of thicknesses available so you can pick how much you want to lower it?
Who sells them?
I don't know of any being sold, but I am sure your local machine shop will make one for you. As a ball park figure, I would make it 3x as thick as the stock head gasket, but don't quote me on that. Lower compression will help with detonation. The most important thing is proper tuning. You can get away with a lot of boost with few mods, or you can blow your $5000 engine up in 30mi. I have been casually researching turbos for a couple of years and the more I know, the more I realize I don't know.
Contour--It will make a master mechanic out of you!
95 LX MTX Bolt-ons
95 Neon SOHC ATX
77 Dodge Powerwagon-more displacement than my Neon, Contour, and wife's Saturn---combined!
Posts: 4,713 |
Do your research, Paul. Adding un-cooled boost will increase your risk of detonation. Unless you like rebuilding your engine all the time, I'd suggest getting the intercooler from the get-go. My .02
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 5,810 |
Originally posted by Derk2000: Do your research, Paul. Adding un-cooled boost will increase your risk of detonation. Unless you like rebuilding your engine all the time, I'd suggest getting the intercooler from the get-go. My .02
You can say that again!
Just so you get the point.
See My Mods
Posts: 3,732 |
Russell
Oval Port 3L Nearly Done
Posts: 7,025 |
Originally posted by Russell: can my stock motor hold up to 50 psi of non-intercooled boost?
haha, yeah that T-28 should provide more than enough.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 3,732 |
Originally posted by beyondloadedSE: Originally posted by Russell: can my stock motor hold up to 50 psi of non-intercooled boost?
i was thinking a quad turbo setup, i can store the turbos in the passenger seat
Russell
