Posts: 1,346 |
i was wondering if anybody had any trick tuning techniques that will shave off a few tenths of my 1/4 mile time? -thnx
E1 CSVT
s/c-----x
turbo---x
3L------check
I am Canuckian
I am Canuckian
Posts: 4,168 |
Regular Contour or an SVT? May help the gurus answer your question.
Green 96 mystique gs 4cyl mtx
16.9 in the 1/4 mile @102500 miles
95SE in Midnight Red MTX
MSDS headers and y-pipe
SVT exhaust
SVT UIM
Optimized se TB.
Full pre 98 SVT body kit
15.741 @ 87.73mph :)
Posts: 803 |
take out spare...take out all passenger seats...lower the pressure in tires...hope for mayba 1 10th of a sec from that
FORSALE - 17" FSVT Wheels, TRubendz catback w/magnaflow muffler PM ME
02 celica GT-S 6-spd w/ TRD bodykit
Greddy evoII exhaust, DC sports header
Injen Short ram intake, TWM short throw shifter, 18"centerline storm wheels, Tein basic coilovers
Posts: 288 |
Yeah weight reduction is a big thing. Lighter is faster, well somewhat. Someone once said in a post that running on half a tank helps because of the weight of a full tank. If you want to go all out, remove the whole interior except for what you need, like seats and crap. get lighter weight wheels. Engine wise, take out the a/c, underdrive pully replacement with a lighter one, K&N air filter, free flow exhaust ETC... The cheapest but probably hardest way to gain time in the 1/4 mile is to go on a diet.  -Rob
White 95 GL ATX
56K Miles on it.
Optilux By Hella Fog lights (The Angel Eyes)
Driven hard, Just like I like it!
Posts: 160 |
Is it hard to take out the AC in the SVT?
Posts: 240 |
Originally posted by Robert S: Someone once said in a post that running on half a tank helps because of the weight of a full tank. -Rob
I would either run the thing till the gas light comes on (2 gallons left), or fill it to the top, to fight the inertia that all that gas sloshing around creates. Experiment, and record those 60 ft. times!?! Hot Rod magazine says fill 'er up...
-Tavis
'99 SVT Contour #535/2760, born 11/30/98. Toreador Red / Prairie Tan
Wife's car: '00 Saturn LS2. Dk. Toreador Red (no joke) / Graphite
Sunday Bruiser: '67 Camaro rs/SS350 4 spd. Ermine White / Custom Yellow
Posts: 2 |
my devirginizing post... what's going on. so to the subject, weight reduction is not somthing that i think the contour is ment for, atleast not for the most of the people on this forum, taking out seats and spares doesn't count., the real wight is removed in sound deadning and tow hooks and cutting big holes in your stuff. bumpers. not bumper covers; replacing glass with lexan , taking out the support structure under the hood and trunk, removing hood and trunk hinges and tossing some ever so ricey hood pins, back seets in a 4 door, those can go, ac power steering , hopefully i gave someone some ideas, ok to the gas issue. mixed feelings in this department. if your running on empty there is less weight forcing fuel into your fuel pump, and under wide open throtle situations i think that this can make a difference, i guess it depends on fuel cell design, ofcorse a 5 gal cell will do ya good, but how about the 15 gal cell with a funnel at the bottom feeding the fuel lines.... i read somthing about a bigger maf i believe, to the best of my knowlege this'll just make you run lean as crap depending on difference in size, unless your ecu is modified to match.
anyone got some crazy cam's and some lightweight pullies, all motor mania. don't forget your lightned flywheel for rev happyness
well guys show me the ropes
ike
what's with these gay ass smiley faces, they come in a rainbow of colors....
666
Posts: 9,196 |
Originally posted by shaggz: Is it hard to take out the AC in the SVT?
The A/C only draws power from the engine when the A/C unit is turn on, don't waste your time removing it, plus don't you want to cool off when leaving the track
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 3,867 |
Function before fashion.
'96 Contour SE
Posts: 85 |
I know alot of racers use the lexan windows but they are riveted on. Can the lexan be used and still roll up? I have kids so removing the back seat is only a track option. Also anyone ever mounted a 10 gallon fuel cell in the stock location? I would like to put it in the trunk but I do need a spare tire on trips.
98 SE Sport. custom catback, Intrax springs, 3L, 3L valves, APEXi S-AFC, 24# injectors.
Other cars:
72 Challenger 360 motor 727 trans (used for parts)
73 Challenger 340 motor 727 trans 15.60 1/4 with bad miss and clogged fuel filter.
