This is from the PDF i got from Ford which is the addendum to the 2000 Contour manual for the SVT. It also makes no mention of a displacement reduction compression increase. And i noticed SVT took that off their site too.
ENGINE/TRANSMISSION
² Horsepower â?? 200 hp @ 6 600 rpm
² Torque â?? 167 lb/ft at 5 500 rpm
² Redline â?? 6 750 rpm (fuel shut-off 7 000 rpm)
² Compression ratio â?? 10.0:1
² Throttle body â?? 60 mm
² Mass air sensor â?? 70 mm
² Air filter assembly â?? large capacity, conical
² Upper intake manifold and cylinder heads â?? Extrude Honey polished
² Lower intake manifold â?? 32 mm
² Pistons â?? Unique design, aluminum-alloy
² Camshafts â?? special design intake and exhaust cams
² Flywheel weight â?? 18 lbs
² Fuel injectors â?? 19 lbs/hour
² Oil cooler â?? block mounted, water-to-oil cooler
² Engine cooling â?? heavy duty radiator core
² Exhaust â?? Quasi-dual exhaust
² Transaxle â?? MTX-75 5â??speed with high performance clutch
