sorry to here that but if its not to bad try some acetone i used it to get the paint that u use to touch your car up off and it just takes the wax off so u have to rewax your care after u use the acetone hope that helps
2000 ford contour se sport
v6 5spd
mods:
kkm intake
tanebe exhaust muffler
dynomax glass pk resonator
jet performance chip
painted rear refelctor/painted front grill
bosch plt +4
all xenon super white bulbs
Sorry to hear about your car. Lacquer thinner might get it of but you have to be gentle. If you're good with a buffer, some heavy compound will take it off. If it's on your glass use a razor blade.
Maybe some goof-off, then try the clay bar, or just try the clay bar first. I had stain-over spray on my car and the clay bar took it off. Good luck, and that sucks.
Austin -officially a troll
See it here
Pro-Flow w/ optimizer STILL for sale
I had this happen to me as well except it was accidental. What will get it off depends on how long it has been on there. Its very important you get it off asap before the sun cooks it in better. With mine it was 4 days before I could do it due to my typical bad luck and unforseen circumstances. I had to use lacquer thinner and my clear coat is now fugged up badly. If you can get to it quick I would go with the suggestion of the clay bar or goof off first and pray for the best. Good luck.
Formerly known as Sneaku
I MISS MY BABY!!!
'00 Blk CSVT #1087/2150 built 12/23/99
Time is key. I got some overspray on my rear bumper. I used a sponge made for removing tar and just pushed hard. It got most of it off. There's still a light haze but it just looks like a shadow.
Do you know who did it? I say Eye for an Eye. So catch them and spray paint them!!!
-Rob
White 95 GL ATX
56K Miles on it.
Optilux By Hella Fog lights (The Angel Eyes)
Driven hard, Just like I like it!
A can of bug and tar remover did the job with no damage to my clear coat I know who did it and he's taken care of already Thanks, for all the suggestions.
Do NOT use laquer thinner or acetone or MEK! Way too strong of solvents. Use a paint prep cleaner or a enamel or urethane paint reducer instead. The others will screw your finish up bad.
Jim
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats".--H.L. Mencken
Bumper sticker,
OXYMORON #65 - Liberal Thinker
