#67235 07/27/02 11:57 PM
Oh.....I forgot that the dealer wants to replace the idler pulley due to the noise I reported a few days ago.
This is the 3rd pulley.
What the (&@#$ is going on!!!?
1995 Mercury Mystique GS Sport
2.5 Duratec
K&N Drop In
High-Flo exhaust
Tint
Bad things:
- clear coat flaking off!
- timing chain going
- idler pulley defunct
- rack and pinion going bleh
- Ford dealerships
#67236 07/28/02 12:11 PM
You mean this is the 3rd idler pulley or the third pulley they've replaced? If this is just the third pulley they've replaced, the Idler pulley can be a culprit in squealing problems. If the bearings go bad, then the belt will slip because the pulley isn't spinning smoothly and the shot bearings make it "catch".
If it's the third idler pulley, either your belt is eating them for lunch or your mechanic doesn't know how to put them on smile
#67237 07/28/02 01:55 PM
Thanks for the reply.
This will be the third pulley the dealer has installed.
2.5 Duratec
K&N Drop In
High-Flo exhaust
Tint
Bad things:
- Ford dealerships
