I just replaced the lower speedometer cable for the second time in nearly two years. The first time the cable bit the dust the dealer replaced it along w/ the VSS (it also would not shift out of 1st). Last week the speedometer stopped working but the car shifted normally. I got a new cable from Ford and put it in myself. Has anyone else had repeat problems w/ the cable? Why did the VSS go bad the first time when the cable severed and not this time? I made sure the cable routing did not have any severe bends and even lubricated the top connection. I hope I do not not have to replace the cable every 2 years. The car has only 36k miles. The first occurence it had only 18k on it. Anybody out there w/ similar experiences or insight/suggestions I would love to hear from you.
1995 Mercury Mystique LS OBD1 2.5 L Duratec ATX- No modifications 70,000 Miles w/ O.E. Water Pump or Replaced: VSS, Lower speedo-cable(2X) Use: Mobil 1 5w30 and Techron Fuel Treatment.;) and Mobil 1 ATF Change every 10,000 miles
Webmaster
Webmaster
Not sure... but you probably didn't get any responses because cable driven 95's are fairly rare. They switch to electronic speedo some time mid 95 so there isn't even a full model year to draw info from.
-Lance
Lance Kinley CEG Webmaster 95 SE, "Cassandra" 10 years!
H
H
Still one out there. I'm at about 90k and the original owner. I had the speedo cable replaced about 3 or 4 times while it was under warranty to about 30k or so. It would occasionally wiggle around and then go back to normal. I've just gotten sort of used to it and it still does it once in a while.
'95 Contour LX V6 ATX
Here's a question. We have a 95 MTX Zetec with a cable operated Speedo. Anyway, there's a terrible rattling sometimes when you come to a light. Terry and I thought it might have been the clutch disk springs, but after changing the clutch, the sound is still there. I am suspecting the Speedo cable. Has anyone ever heard of this?
00 SVT Contour (1584) 04 F-350 XLT Sport V10 02 Honda Spirit 750 64 390 FE Big Block
My speedo usually wobbles around 20-45MPH... I've learned to ignore it because whenever I see a radar unit on the side of the street which displays your (the drivers) speed, my speedo is right on the displayed speed... not inaccurate, just wobbly often.
Should I replace the cable or just let it do its thing?
BTW, my Mystique was manufactured sometime in July 1994 and has a little over 60k miles on it
'95 'stiqueLS 2.5L ATX S&B / CTA intake KEM Mag-Plus wires 1/4" TH fix Homemade heat shield Xenon bulbs Fog light rewire ATX cooler Flowmaster 942042 Blacked-out pseudo-chrome
When yu are stopped, the speedo cable isn't turning. Might be gear rollover - the tranny spinning a little at stop and the gears make a little rattle.
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
W
W
170000 km still the same cable.
2012 Lotus Evora --------- 95 Mystique MTX - GONE 395,000 Kms --------- Both Zetecs '97 Contour Mtx - stock - GONE
140 K miles on the same cable. A little wobble, but no problems with the upper or lower part so far.
O
O
-Lance
Man that just sorta made my day. I gots a 95 and I was kinda disappointed that I couldn't get the indiglo guages because I had a cable. Now you say that not all 95's are cable driven. My speedo nor tach doesn't shake or anything weird. So does this mean I have a digital? What other means can I use to tell if I have a cable/digital speedo/tach?
95 Mystique GS Zetec ATX: Dead - Dec 5th, 2003 94 Accord LX 2.2L MTX Non-Vtec. Few bolt ons. 02 Escape XLT 3.0 V6 ATX. This thing has the CD4E in it?! What the hell was ford thinking?
[quote What other means can I use to tell if I have a cable/digital speedo/tach?
Look at the vss unit (on the back of the tranny, bottom of the firewall, down low). If you have only electrical wires coming out of it, you have an electronic speedometer. If you have a somewhat rigid cable, about the diameter of a pencil, coming out of the vss, and going up and through the firewall, you have a cable speedometer.
