Posts: 2,291 |
It's so easy, I've done it on a break at work (and I work in an office and need to be clean).
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by D Davis: It's so easy, I've done it on a break at work (and I work in an office and need to be clean).
It is too easy. That is if you know where it is.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 21,653 |
haynes manual says I need to drain the coolant first, is this true?
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 21,653 |
done. lost more coolant than I thought I would but it's cool because I got to add just water and that helped to changed my old 50/50 ratio to something better. driveway smells like fish now. ![](/ubbthreads/images/graemlins/grin.gif) i recommend this for EVERYONE that owns a zetec to do. it's simple, quick, and easy to do. All you need is a flat head screwdriver, 8mm socket, extension, ratchet, lower temp thermostat (~$15), gasket ($3), and water. It ran on 'O' the whole way home tonite, usually it would be around the 'M' and sometimes higher.
98.5 SVT
Posts: 21,653 |
one question though: this thermostat has no air bleed valve like stock. does that matter?
98.5 SVT
Posts: 21,653 |
another observation: tonight, temp. in 80Fs. on drive home from work, i had defroster on because of rain. the whole way home the temp gauge sat right at bottom of the 'N' and as I came into my driveway, it was barely sitting in the NORMAL operating range area. it really helps a lot.
98.5 SVT
Posts: 76 |
drill a small hole in it.
Posts: 750 |
hm...
#1 If the temp is too low, the PCM will think the car is in warmup mode and will rich the mixture all the time. I had this when my temp. sensor went bad. Car ran like a champ with MPG below 20... Not something healthy.
#2 I was told the hotter an engine is (i.e below warpage/ fluid boil limits of course) the more efficient it is, that's why we don't run our engines at room temperature. What's the truth about it ?
T.
Posts: 21,653 |
1.it's still in normal range 2.untrue, that's why we want colder air and that's why nitrous is used
98.5 SVT
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Kremithefrog: 1.it's still in normal range 2.untrue, that's why we want colder air and that's why nitrous is used
Well nitrous is not necessarily colder....it burns A LOT more effiecient than "regular" air. Nitrous is an oxidizer.
Hector
257HP/259TQ
160HP/141TQ
