Posts: 70 |
As soon as I start the car the fan comes on, which I know it shouldn't. Also sometimes it won't start right up, like its flooded. I pulled codes 998 and 17. Anybody have any ideas as to what is going on.
95 Contour Gl - the work beater - bought 6/15/03
88 S-10 Blazer - back up beater - owned since 89
97 Cobra Vert - my weekend toy - bought 12/01
Posts: 160 |
'95 Contour SE, MTX, Champagne
'03 EB Expedition, Med Wedgewood Blue
Posts: 70 |
KOER - Did not pass Key On Engine Off test yet (Get 111 in KOEO first) (Generic EEC-IV reference source)
I couldn't do that test, I don't know why it wouldn't work. Code 17 says something about the o2 sensor
Posts: 2,319 |
According to code list in FAQ section, code 117 would be more in line with your symptoms. Code 117 is displayed for ECT(Engine Coolant Temperature) sensor problem, which might explain fan operation.
Posts: 70 |
Originally posted by horseydug: According to code list in FAQ section, code 117 would be more in line with your symptoms. Code 117 is displayed for ECT(Engine Coolant Temperature) sensor problem, which might explain fan operation.
you know what, it might be 117. I'll have to double check tomorrow. I can't wait to get this car running straight.
Posts: 160 |
Heh! horseydug --
I finally found my way to the codes section of the FAQ (I knew it was there somewhere). As it turns out, the "Generic" source (which I D/L'd from another site) is the same one as is in the FAQ. And, I agree, the 117 seems as though it would be more plausible.
Posts: 13 |
The symptoms you describe are exactly what would happen if your coolant sensor was shorted, 117 is the proper code but the fan will only constantly run if there is a short in the sensor or the harness is off the sensor, check to make shure your making proper contact with the sensor.
