Posts: 60 |
After 8 long months and 2 bad engines I have a running 3L (170psi). It's a 98 block and heads with SVT cams as well as an aftermarket flywheel, 4 new O2 sensors, FMS wires, Pro-M 75mm calibrated for 24's. The engine seems to be running ok with one exception that I can't figure out for anything. The car is kicking the CEL with codes P301 through 306 (Miss-fires at all times. When accelerating it will hesitate really bad until around 3500 at which point I have no trouble all the way to redline. The car has a new Cat in it with punched out Pre-Cats. Originally I had thought that the car was running lean. After taking out the plug today (autolite copper core .48 gap) they are carbon fouled.. black as can be... indicating a rich condition.. I can't figure out why it would be though. If anything I would have thought lean without MIL eliminators in place for the hollowed Pre-Cats. ?? Any suggestions would be great.. can't figure this one out at all. Also I must mention that this is my second set of plugs in the car after noticing the first set being fouled. I have also replaced the TPS with the 3L one as the original was bad. I have also replaced the IAC.
-Nate 98.5 SVT -all the goodies
Posts: 352 |
Nate:
A couple of things here strike me as odd... They might give some insight as to why you're misfiring...
-Wires: Wires will cause misfires very quickly- Are they brand new? Worn in any way? Did you use dielectic grease between the wires & plugs, and wires & coil?
-Copper plugs: The SVT cams and computer that you're using are computing A/F and timing based on a very hot, platinum-based spark. The only time I've seen coppers is under FI.
-Rich condition: Unburnt fuel and carbon build-up from those misfires. I would tend in this case to verify the MAF/Injector combo. Which injectors are you using? Are you positive on the MAF calibration? Extreme rich in the low band is screaming either bad induction or bad A/F calculations.
-TPS: After installing the new TPS- Are you properly calibrated? Proper voltage ratings are critical at closed and WOT. This would throw off the A/F mix really quickly.
-MIL Eliminators: Recommend these, but only to avoid the "catalyst below efficiency threshold" CEL. Those two O2s are for that function only- I have seen no evidence that their signals influence A/F mixture.
Hope something here turns on a light for ya...
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
Posts: 60 |
DanG, The wires are brand new. The main reason for copper plugs would be that I do run Nitrous in the car or I should say will be once it is running right. The TPS is calibrated correctly. The MAF is calibrated for 24 pound injectors and was custom done for the car. I am running 19 pound injectors as of today because the 24's that I have seem to have bad seals on them. I would think that with the 19's in there the car should still run ok as I had this same problem even with the 24's.
-Nate
Posts: 352 |
Nate:
Now THAT'S weird. You shouldn't be running the 19#ers on the 24#-calibrated MAF, but that would make you run LEAN (injector pulse width shorter because of the 24#ers more ample fuel delivery).
I now can't imaging why you're running rich and/or fouling... Try the stock MAF for as long as you're running the 19#ers... See if that makes a difference.
Posts: 60 |
Just tried the stock MAF with a complete reset of the computer.. still has a missfire.. getting a missfire in as many as 4 cylinders. I am going to try swapping out iginition packs with an extra that I have here as well as checking the ends of the FMS wires to make sure they have good contact..
Posts: 5,810 |
change to stock plugs and wires! Do it now! Hurry!
See My Mods
Redneck Troll
Redneck Troll
Posts: 2,621 |
Dang it Tom... I was half way to the door to change my wires back to stock. Don't yell at me like that!
http://www.bnmotorsports.com
Posts: 60 |
yeah I'm about 20 minutes away from trying that one.
Posts: 60 |
Ok.. tried the wires... no go.. still missfires and toss's the codes for it. I am going to try a different ignition pack to see if that will help the issue any.
Posts: 5,810 |
See My Mods
