Page 2 of 6 1 2 3 4 5 6
Yes,
A starter and solenoid can be checked at your parts store. I believe you can also jumper the wires to test the functionality.
Connect a fused wire from the positive terminal of the battery to the small terminal on the starter solenoid. If the starter works, and engages the engine, then you know the problem is between the solenoid and the switch. (Such as a neutral/clutch switch, and so forth.)
Otherwise, if it doesn't crank, then your starter/solenoid is suspect.
Make sure the transmission is in neutral before you test this. You might even turn the key on after testing the starter, if you are curious if the engine will start.
HTH,
TB
Tony Boner
Plug in the sol cable nr the battery...... wink
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Every connection is hooked up. Checked the battery to sol connection (black to black/grey connector) and it's connected.
Simon W. Las Vegas.
96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!)
1999 SVT Engine
SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT
"it's only nuts and bolts" - Terry Haines
"Drive it like you stole it" - Me!
I'm not sure you understand what I was saying. If you "jumper" the solenoid, you are basically checking the starter by checking its operation without removing the starter.
That is if you were replying to my message. Otherwise, nevermind wink
TB
Tony Boner
Hit 'unlock' twice on the remote....
V6 MTX
I don't have keyless entry. It's a 96 car.
Simon W. Las Vegas.
1999 SVT Engine
Originally posted by javaContour:
[b]Every connection is hooked up. Checked the battery to sol connection (black to black/grey connector) and it's connected.
TB[/b]
Yeah, sorry, I was responding to Terry. I'll try what you said though for sure tonight after work.
Simon W. Las Vegas.
1999 SVT Engine
Another stupid thought. All fuses/relays good? Maybe fuel pump relay? Again speaking out of my As$, but you never know.
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Check all fuses and relays and they are all fine.
If anyone can correct me on this please do, but I "think" that the fuel pump only turns on if it's "told" to, i.e, after the starter motor engages etc and the computer relays that to the fuel pump and on the turn of the key to crank the engine it starts to pump. I don't think the fuel pump starts to pump when the key is at the 2nd position (just electrics) does it? Should I have preasure in the fuel lines before the engine is cranked?
So I'm really thinking that it's the starter motor (or at least, that's probably what I'm making my self think as then I know what the problem will be and be able ti fix it). If it's not the starter motor, then I'm screwed! as I will have NO clue as to what is causing this.!! Fingers crossed everyone for the bad starter motor!!
Simon W. Las Vegas.
1999 SVT Engine
Okay,
Here is my .02.
You got a new battery, okay.
You installed an SVT Engine into a 96 tour, right ??
Did you swap ALL of the sensors and wiring harnesses from the from the Old 1996 engine to the SVT engine ?
If not, then there is your problem.
You have to use the ORIGINAL WIRING HARNESSES and sensors.
Oh, when you turn the key to the ON position, and LEAVE it there,
the Check Engine light will flash ONCE and then stay lit.
This is normal.
Also your fuel pump will energize for about 10 seconds to pressurize the fuel rail.
Also, with your new SVT engine, make sure you use 91 octane or better.
The SVT engine has a HIGHER compression than your old 96 engine
and requires 91 octane to keep it from knocking itself to pieces.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
