Page 4 of 6 1 2 3 4 5 6
Simon,
The sol is part of the starter,pull the plug we have been discussing and run a '+' line to it from the battery,if the starter engages and turns its not the sol, trace the sol line back to find the fault causing no power to the starter..I still dont think you need a new one!
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Originally posted by Terry Haines:
Simon,
Oh ok. So that's not what I did then? I had a + line from the battery going to the smallest of the 3 screws on the sol and the starter engaged and cranked the engine when I re-connected the battery - cable.
So you saying to disconnect the plug (near the battery, black wire connecting to the black/grey wire) that connects to the sol and "then" run the + line to it?
oh and I didn't order a new starter, just a sol. Thinking that the sol is what is bad and not the starter it self as it engaged the engine when I did my test.
Simon W. Las Vegas.
96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!)
1999 SVT Engine
SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT
"it's only nuts and bolts" - Terry Haines
"Drive it like you stole it" - Me!
The small wire is what trips the solenoid.
The solenoid has a large gauge wire to the positive terminal of the battery, another fairly large conductor that goes from the solenoid to the starter, and the small wire.
When you apply ~12V to the small conductor on the solenoid, it "trips" the solenoid. One of the solenoid's functions is to connect the battery terminal to the starter, providing a path that allows a very high current to flow, enabling the starter motor to turn.
So if the engine cranked when you connected a 12V source to that small terminal, you demonstrated that the starter and solenoid are good, and that 12V is probably not getting to the switch terminal on the solenoid.
Put a multimeter on that small terminal and turn the key. I believe you should see 12V when the key is turned to the start position.
If not, then something is wrong in the circuit from the keyswitch to the starter.
TB
Electricity is not tough, just think of it as plumbing that can kill wink
Tony Boner
Ok, so what if I do get 12v on the multimeter? Where would the problem be then? Somewhere in between the ingnition and battery?
Simon W. Las Vegas.
1999 SVT Engine
Terry and Tucker were right!!
The sol is GOOD. I setup my testing wire again, this time I had both battery connections on, I disconnected the plug that is from the battery to the starter (the one you was talking about Terry), and I connected the croc clip to the inside of the plug on the starter side and the engine cranked. So the sol AND starter are fine.
But now I'm back to square one!! How can I find where the problem is??
I tried to use the voltmeter but I haven't used one since high school! I didn't know which setting to put it on to measure Volts. So I tried all of them!!..lol none gave me a reading of 12. (I had the black cable connected to the - on the battery and the red to the sol while I had the key in the ON position). I'm sure I was using it wrong.
Anyways........NOW WHAT!!???!?!?!... frown I'm sorry to be a pest guys but I am really stressing over this! I didn't come all this way for it to not work due to a damn WIRE connection or something.
Oh, and not sure if this is related or not...but my fuel pump doesn't seem to be working either? I don't hear it come on when I turn the key and I have no preasure in the fuel lines? Coincedence or is this maybe another problem due to the fact that maybe my problem lies in the ignition switch somewhere?
Simon W. Las Vegas.
1999 SVT Engine
Did some more fishing tonight and going throught the Haynes. I checked the relay for the ignition in the main fuse box, haynes said you should be able to eahr it clicking on and off with the key, if not, it's either the ignition or relay. Well, I can hear it clicking on and off so that's ok according to haynes. So the ignition switch must be fine also.
I don't know where else to look. I'm lost! frown mad frown
Simon W. Las Vegas.
1999 SVT Engine
Checked on the Ford CD, it says to run a EEC-V KOEO Self Test....what the bloody hell is that??? (couldn't find it on the CD nor the Haynes)
Simon W. Las Vegas.
1999 SVT Engine
Stupid question, but have you double checked to make sure your clutch interlock is working?
97 SE MTX, KKM, UR UDP, 19# Injectors, SVT TB, SVT UIM, SVT Flywheel, Grizzly Street Clutch, Upgraded motor mounts, mystifed precats, brand new main cat, SVT exhaust sans resonator, 205-55-15 Dunlop SP5000's
154hp / 156 tq before the SVT exhaust, SVT dual honed upper and swapping the mystery main cat for mystery precats.
My Profile
KOEO = key off engine off...someone else can tell u for sure but if u have a code reader and/or booklet there should be instructions for running the test suggested by your cd
from there u can get the code(s) that tell u clear as mud what may be causing your problem
i was gonna say take the car to autozone but duh on my part shocked
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
With the voltmeter back where it was turn the key to the sprung 'crank' position, this is the only position you should get a reading on the meter,just run does not supply power to the sol.....
V6 MTX
