#66654 07/20/02 02:53 AM
F
F
Anybody ever had this happen to them....
If I put the a/c on, the temperature gauge starts rising..... and if i put it on high, it starts heading for the "red" real fast.....
Just had the water pump, and thermostat replaced.
The coolant was also flushed (for real, as far as I know).
I also had serperntine belt changed.
Anybody have a clue what it could be?
I'm having a/c checked next week.... it isnt as cold as it should be (and once was), and the fan comes on all time with it on.....
Thanks in advance for everybody's opinion and help....
#66655 07/23/02 02:34 AM
F
F
Anybody care to venture a guess??
#66656 07/23/02 03:09 AM
Thats funny, it seems like my car runs COOLER with the A/C on. confused
YOUNGEST CEG MEMBER smile
1995 Mystique LS V6 ATX, Moonlight Blue Clearcoat Metallic, Atlantis blue cloth. Fully loaded except leather, sunroof, and CD.
1990 Pontiac 6000 S/E AWD
Brilliant White with 2-tone Gray leather, fully loaded
#66657 07/23/02 03:41 AM
Fans aren't operating properly. They (or it or one of them) are supposed to come on when the AC is on. Just a guess.
#66658 07/23/02 04:55 AM
I have to agree bout it bein' da fans. my ac cools the engine
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
#66659 07/23/02 07:50 PM
If this is on a V6, The WP is driven by a different belt. (DS of the front cyl bank.) Might want to check that belt and tensioner. The fan is supposed to come on full time if the AC is on. It shouldn't make any difference if the AC is on normal or max because all this does is recirculate the cabin air instead of cool new outside air.
Scott
#66660 07/23/02 07:55 PM
Try running the AC on MAX.
The engine should run cooler.
Running the AC set to A/C circulates OUTSIDE WARM air across the evaporator
which translates to more heat coming from the Condensor.
If the condensor gets hot, then the fans will suck
the extra heat across the radiator, making the radiator warmer.
When it runs on MAX, you recirculate the interior air.
As the interior air cools down the condensor will also cool down
since ther is less heat in the air for the evaporator to extract.
This will translate into your engine temp coming down as well.
At least this is how it works on my Tour.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
#66661 07/23/02 10:02 PM
F
F
Thanks Pete, that makes sense and it sounds like it'll help but what I really want to figure out is why the car starts to overheat when I have the a/c on, and why this only started to happen after I took the car to my mechanic (dumb schmuck.) to change the water pump (metal impeller), thermostat (Motorcraft - stock - oem), dual mode dampner, and both belts...
I guess what I'm trying to say is that I want to fix the source of the problem, and not just the symptoms.
Frank
#66662 07/24/02 04:52 AM
H
H
Might help if you could give you car details, although most of us are assuming v6, due to wp replacement. Also 1 or 2 rad fans?
What's the temp gauge doing w/o a/c on and will the rad fan(s) come on if you just sit at idle, in park, for a while with a/c off?
stock CD on LS, cass on LX
4 wheel discs on LX only
#66663 07/24/02 05:24 AM
tiv Offline
Some Zetec people (including me) are having this:
upon meeting of the following conditions:
- hot & humid air outside
- A/C on (whatever setting)
- constant high speed for cca. 1hr (80-90mph)
the coolant temp starts to rise steadily (I always chickened out and switched off A/C when the needle hit the right edge of the scale before the red zone, so I can't confirm it does overheat).
strangely enough, after switching off the A/C the temperature goes back to normal in 1-2 minute.
another strange thing is that when I switch on the A/C again it'll blow in dense fog/mist/vapor so that all my passengers get scared laugh
Dunno what causes this. Doesn't happen when the air is hot but not humid.
Don't think it has anything to do with engine overload, but it never happened below 80mph.
Do you have something similar ?
Tiv
