I was on my way home today from work and had the AC cranking! 93' degrees in PA today... So any rate. I am tunnin'along at about 75 and look down at the temp gauge and notice its almost in the "RED" zone
I imediatly freak OUT and turn the AC off and turn the heat on!!! It moved down a bit.. The issue is that I have NO idea how long it was on! Its a half hour drive home from work... The car ran fine NO steam while driving. Nor NO smell of anti freeze? I do NOT think it hit red nor pegged any of the time. I drove home. Popped the hood and there was crackling (steaming) but NOT much...The Water resivoir was almost at the top of the cap!
I let the car cool and went out to see if the water dropped, sure enough the resivor was EMPTY.. It only took a 3/4's of a gallon of water to get it back to the line....
The car has 61,000 miles on it! No signs before of any trouble.... Could I have done anything to the motor with it just getting to the tip of red in the gauge?
After I added the water I started it to circulate it? The water did drop after I started it. Could it be the pump? I squeezed the the large radiator hose next to the battery while it was running, would I be able to feel any water flowing thru it? I felt NOTHING? But I was at idle rpms... Not reved,,,,
My buddy is a mechaninc and he is going to change the thermostat, pump, belt and flush the coolant... Monday.... The car sits till then
The real pisser is that I had the ESP to 60,000 miles... I am 1000 over!!!! Son's a biatch's....
Hey doesn't it mean YOUR 60,000 added miles and not from 0 (ZERO). I bought the car it had 24,000 on it already!!! LOL...... So the warranty should go till 84,000... :rolleyes: I paid full price so why don't we get the miles/warranty we paid for!!!! HA HA .. Stick it to us FORD.....
Thanks for any help you can throw at me and I know this is a ongoing topic that we all will run into while we own these cars....
Spankey
97 Sport V6
