9
9
Ford told me today that my Timing belt was loose! I didn't think this possible. They have already hit my up 500 dollars for an alternator (stupid me for taking it to ford). They want 500 more for the timing belt.
Are they telling me the truth?
97 Contour GL 4cl
K&N inbox filter
ICW Racing 17 inch wheels
Powerstop crossdrilled rotors
Mintex pads
135,000 plus and still rollin smile
$500 is too much for a timing belt. I had the timing belt and some other service on my 96GL and it was only $350
So unless you mean $500 Canadian pesos, it seems a tad high.
Dunno if it is true or not, I'm not familiar with your original problem. Perhaps they are just recommending changing the belt since they do wear out.
Remind the service manager that much of the work is already done during the alternator replacement, so you don't want to pay for stacking the charges.
TB
Tony Boner
9
9
Here are some picture of my timing belt which I think looks fine. What do you guys/gals think?
Timing belt pictures
97 Contour GL 4cl
K&N inbox filter
Mintex pads
9
9
Yes they want 500 American dollars... I called around last week and got estimates of around 300 to 350.. I just don't think it needs it..
97 Contour GL 4cl
K&N inbox filter
Mintex pads
Has it been done yet on your car? If your @135000 and it hasn't been done then there is no question that it should be. Just shop around for the best price. Remember this is cheap insurance. Also the recomended interval is around 60000miles/100000kms. :p
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
9
9
It bought the car when it had 69,000 miles on it.. I am not sure if it has been done. Looking at the pictures I realy don't think that the timing belt would look that good and have that many miles on it.
97 Contour GL 4cl
K&N inbox filter
Mintex pads
Something smells fishy... There is a belt tensioner that should keep the belt tight and maybe this is a problem. (?) Timing belts just don't stretch a whole lot so a new belt isn't going to be much "tighter". I'm not that familiar with the Zetec, but $500 sounds way out line, especially since the belt looks to be completely external. From your pics it doesn't look that bad, but you have to look at every inch carefully for cracks or "chunking" to know for sure. Might try a post in the Zetec forum and see how many DIY'ers have done it and how long it takes. I doubt the belt/part would cost more than $120 or so.
Scott
