Page 4 of 9 1 2 3 4 5 6 7 8 9
#665291 06/21/03 01:09 AM
Sooooo adjustable cam gears do just that adjust your cam into different durations, etc? How does the timing chain react? Sorry guys I'm stupid here today.
#665292 06/21/03 03:56 AM
It changes (retards/advances) the valve open & closing points in relation to everything else. The duration would stay to same as the cam lobes do not change.
"Very basically" it raises or lowers your powerband. Advancing (making then open & close sooner) would generate better low & midrange torque numbers while sacrificing up top (I.E. NOT what to do on our engine!)
Retarding (later valve action) them would move everything up the power band and generate better HP numbers. Exactly what a well breathing, high compression engine needs!
Being as there are both an intake & an exhaust cam the phasing of the cams can come into play as a potential power enhancer.
For instance really tweaking the exhaust cams to make up for the abysmally small exhaust valves.
Changing the valve overlap (ahem FI'd folks)
However like most things there is always a subsequent loss for your gain. Nothing is ever truly free. It's just figuring out what losses and gains are best suited to the engine design and purpose.
As for the timing chain. It sees nothing different. It wraps around the gear sprocket and turns it just like normal.
#665293 06/21/03 04:12 AM
yeah for a duratec.... ever see ddavis's dyno plots for his cam gears.. haha take that duratecers.
#665294 06/21/03 04:22 AM
No. That's just the simple physics of it.
When you alter the powerband like that you have both a losing and gaining end. Now if the losing end is in an rpm range you hardly ever use than losing it may not be considered a factor but it is still a loss.
#665295 06/21/03 04:29 AM
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=dynodrag&Number=245738&page=3&view=collapsed&sb=5&o=93&fpart=1
i'm not great at reading dyno plots, but there doesn't seem to be a loss of power any where. i guess it's just a zetec thing.
#665296 06/21/03 05:39 PM
Thanks Demon exactly what I needed
#665297 06/21/03 07:31 PM
Since the cams are heat treated, wouldn't the cutting process be an issue? How can they be cut without getting too hot and become weakened or distorted? The fact that they are hollow, would it cause any integrity issues after having a closed end lopped off of it?
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
#665298 06/22/03 03:46 AM
W
W
The cutting will heat up the metal locally, but any cutting shop should use oil or liquid cooling of some sort with a decent cutting blade. The properties of the metal will only be affected in a very local region.
Besides, these cams are assembled parts, the gears the lobes and journals will all be heat treated, but the tube may not and parts that fit on the tube are probably done at a different time. This is probably not a big issue.
#665299 06/22/03 04:08 PM
I guess there's one way to find out Hopefully Kinger's machinist can pull this off for a set of prototypes.
#665300 06/23/03 06:00 PM
soooooooo...... i can get my hands on a set of SE cams.... kinger you upto it?
2000 Cougar V6 MTX 2001 3.0L Swap w/ PnP Heads - It ran, it boomed, it RUNS AGAIN Nearly all suspension mods Big ass stereo ...and more... See Her Here
