#66476 07/18/02 04:54 AM
Stephen Offline OP
Ok, is it normal for the Zetec to cut out when you rev the engine while in park?
It sputters, for lack of better words, only when you rev it in park but it has great get up and go while in drive!
Is it the rev limiter at work?
Thanks in advance for your reply,
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
#66477 07/18/02 05:10 AM
mine does the same thing, i belive it is the rev limiter at work. smile
Adam
Electric red
95 Ford Contour GL
ATX Zetec
Born on date 11/1/94
Big changes coming......."hint 95 Ford Contour SVT".
"This is a place for crazy people I'm not crazy." Brad Pitt [12 Monkeys]
#66478 07/18/02 05:36 AM
In neutral or park it's limited to around 4000 rpm.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
#66479 07/18/02 07:06 AM
I heard it is so you can't neutral drops. confused But mine is the same way.
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
#66480 07/18/02 04:51 PM
Yup mine does the same in Park. It appears to be limited to 4300 rpm.
On another thread I can't remember which one someone spoke of the car suddenly surging with power during accelaration. I do indeed experience this and am glad to know this is normal.
http://members.rogers.com/pc.cobra
1998 Contour SE,sport, Zetec.
