DPFE should have two hoses attached to it, both of them coming from the EGR tube.
If one of the hoses is missing, then your CEL should be lit.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
