#664042 06/15/03 12:13 AM
last night i was driving home from work and started to hear an exhaust leak,to-day i looked and found that there are two tubes that come off the EGR tube,one goes to the DPFE sensor under the EGR valve which only has one connection and the other tube has no hose on it,where does it go?
ANY HELP IS MUCH APPRECIATED............
thanx in advance.
1999 silver frost contour SVT #1951 of 2760 born 4/20/99 81,000 kms side exit exhaust pulley's hood gadges SOLD
#664043 06/15/03 01:00 AM
DPFE should have two hoses attached to it, both of them coming from the EGR tube.
If one of the hoses is missing, then your CEL should be lit.
#664044 06/15/03 02:00 AM
well if the DPFE is right below the EGR valve on the motor itself ,there is only one spot for a hose is that posible? i have no CEL either........
#664045 06/15/03 03:10 AM
I
I
thanx in advance.
I just replaced my DPFE a couple of days ago, 99 CSVT. There are two rubber hoses to it, 2 different diameters. The tubes on the DPFE that they connect to are 2 different diameters to match the hoses. I didn't follow the hoses down, so I don't know where the hoses originate.
contours, deloreans & fiats, oh my!
#664046 06/16/03 10:13 PM
The DPFE does require two hoses, all the way back to 95.
You probably have a cat going, the DPFE hoses don't just pop off for no reason.
