I installed the SVT indaglo gauges in my 99SE Cotour , now my speed seems to be 20 MPH ahead..how might i fix this problem ? I was thinking of changing the speedometer gear to a SVT gear ? will that do it ?
Thx
99 Contour Sport 24 valve
Gutted Cat,Resignator Removed
5% Tinted Windows,
Side strips removed
C10N@yahoo.com
Did you take off the speedo needle when you installed the guages, or did you slip the guages over the needle through the hole for it?
Do you have the actual SVT gauges?
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
Install a set of non-SVT indiglos... or add the actual SVT cluster under your SVT indiglos.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
nope , i dididnt remove the needle , i slipped them over ...are you sure i cant change the speed sensor or a gear ? i got the indaglo gauges all installed on a non SVT car ..i sure this will work somehow ? ...?
let me know /../THX
5% Tinted Windows,
Side strips removed
C10N@yahoo.com
