Posts: 23 |
here are to set ups that i have been thing about for my ignition.
Set 1
plugs: champion double plats
Wires: Accel
coil pack: Accel
Set 2 Plugs: Champion double plats
Wires: Jacobs
coil pack :jacobs ignition pack
well set 1 is lower in cost but i know for a fact that jacobs system will boost hp by 10% or better , i had one system on my 94 nissan Altima with the ka24de motor i had a short ram intake and a cat back system and some other things like under drive pully, i was putting down 145fwhp when i got the jacobs system i was putting down 159-160fwhp that was a 10% increase, so it realy helped , so i was thinking to go that root , but i don't know this car like i did my alty(loved that car)so do you think the tour would take to the jacobs? just picking your minds. oh i started out with 138fwhp 150 to the flywheel i did have a bosh ignition set up and i had royal purple oil in at the time so that may have helped some . let me know what you think .
Posts: 3,465 |
plugs, wires, or coil packs will NOT cause you to gain HP period. however IF and ony IF one or all are bad it will feel like you gained power.
as for what you said go with the accel coil pack IF your stock one is bad if it isn't there is no need for one. wires stay away from the accel wires they are not that great your better off with the ford racing ones instead. and for plugs as been posted in the TWO other post about this in the past 24 hours autolight double plats.
and oil will not give you HP either.
and the search on the site is your friend please use it
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 2,091 |
Originally posted by Azhrei: I know for a fact that jacobs system will boost hp by 10% or better , i had one system on my 94 nissan Altima with the ka24de motor i had a short ram intake and a cat back system and some other things like under drive pully, i was putting down 145fwhp when i got the jacobs system i was putting down 159-160fwhp
that was a 10% increase, so it realy helped.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by 21psi2300: Originally posted by Azhrei: I know for a fact that jacobs system will boost hp by 10% or better , i had one system on my 94 nissan Altima with the ka24de motor i had a short ram intake and a cat back system and some other things like under drive pully, i was putting down 145fwhp when i got the jacobs system i was putting down 159-160fwhp that was a 10% increase, so it realy helped.
HMMMMMMM
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,957 |
is that on the chassi dyno, or butt dyno?
NEED AN SVT REAR BUMPER!!! pm me
Posts: 5,621 |
How any wiring can increase horses???
Posts: 2,094 |
Originally posted by RGSOUNDF: How any wiring can increase horses???
If they were yellow then there was definitely a 10hp increase.
'95 GL White
I've got mods.
Posts: 5,621 |
Well, then I gained 26 HP when I put the CF PIAA wipers from CutsomCougars...
CEG road warrior
CEG road warrior
Posts: 17,248 |
My Top Speed sticker had to give me 10hp (not yellow).
Hector
257HP/259TQ
160HP/141TQ
Posts: 5,621 |
Originally posted by LoCoZ2.0: My Top Speed sticker had to give me 10hp (not yellow).
did it? well, you must have done some mind alternating experiments to get it, probably in the way this writer Costaneda described in his books
