Posts: 65 |
Thanks for the tip. I'll try that when starting. Another question - my trans has a little bit of seepage at the top - noticed it the other night when looking down into the engine - nothing major - no fluid noticable on the sides or bottom, just top - garage floor bone dry. Is this anything to worry about?
'96 Contour SE 2.5L Duratec V6 MTX Teal Purchased New - 9/95 43,000 Miles - I Know, I Need To Get That Water Pump Replaced!! K&N Air Filter/K&N Oil Filter, Castrol Full Synthetic Oil - Switching to Mobile 1 Advance Auto Salesperson (When Not Working At My Reg Job [Wildlife Biologist]) (Hey, Why Not - I Get A 20% Discount & Have Access To All The Parts Catalogs!!!!)
Posts: 5,805 |
If its near the rev light swith its ok, the breather is part of the switch, anywhere else is a leak....
Posts: 1,041 |
How often are the Trans. oil changes?
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 1,861 |
Ford has no specified change interval. I change mine every 30,000 miles. Terry, what's your opinion?
Jim Johnson 98 SVT
Posts: 5,805 |
Depends on use,area,temps etc...I'm inclined to say every couple of years at least.
Posts: 1,036 |
After I switched from normal fluid to Mobil 1 my trans started griding and upon high revs the trans would not let me shift into the gears. I will be switching back to normal Dextron III when I get a chance...
98 E0 Silver SVT KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
