Posts: 117 |
So the other day prior to my big trip I'm starting my car and my battery is not responding like it should. It would have been 2 years old in September so off to Canadian Tire I went with my receipt. Luckily the battery was bad - not my alternator(those types of things tend to deplete your vacation fund very quickly). So a I got a brand new battery for free, I hooked it up and all was well again. NOW MY DAMN DASH LIGHTS DON'T WORK!!!???? I looked at the #31 fuse under the dash(I think that's what number it was). It's a 7.5 red and it looks fine. Could I have shorted something out when hooking up the battery? Everything else works just fine. Is there another fuse I don't know about? Thanks for taking the time. Rob
95 Contour LX Approximately 120,000miles 2.5 MTX Red
Posts: 82 |
When my speedometer and fuel gauge started acting up (as in, not doing anything), I got frustrated and gave my dash a good whack. Now they work fine. No, I am no the Fonz.
98 Silver Frost SVT "I was doing fine until I ran out of talent." "It's not whether you win or lose, it's how drunk you get."
Posts: 9,178 |
Check all the fuses under the dash. I had a similar problem and it was the fuse for the dome light that was bad...IIRC.
Posts: 117 |
I just finished checking all the fuses and there does not seem to be any bad ones. I even swapped the fuse that should be burnt out for another one and still no lights. Any idea what the heck is going on here? I think I shorted something when I put my new battery in.
Rob
Posts: 9,178 |
Did you check the underhood fuses too?
Posts: 1,075 |
It may seem stupid, but check the dimmer...
Ride: 2000 T-red SE Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
Posts: 9,178 |
Originally posted by T-red2000se: It may seem stupid, but check the dimmer... My dimmer is fried. My dash lights only come on when the dimmer is all the way on.
Posts: 117 |
Hi, I don't think it's the dimmer. It does not matter where the dimmer is postioned the dash lights will not work. All the fuses under the dash are good-to-go. Which fuse should I be checking under the hood? Keep in mind that the ONLY thing that is not working are the dash lights and it started right after I installed a new battery. If I did blow a fuse under the hood you would think there would be other problems as well(but I'm not the pro).
Please help, Rob
Posts: 117 |
Hi,
does anyone have anymore information they can offer on this issue? Thanks, Rob
Posts: 3,636 |
Why not the dimmer, it could be an open circuit so no current passes, regardless of the position of the dimmer dial. (Wow, what a long sentance!)
TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
