Thanks.
Here's my (sob) story. Three years ago, I took a glancing blow to my left front fender and door panel. Accident was my fault.
Ater the body was repaired and alignment work completed, I left the shop and the Tour pulled so hard to the left I had to turn the wheel to 2'oclock to keep it straight. Out on I-95, I couldn't do anything over 50 without shooting into the left lane. A damn wrestling match.
I took it back to the body place, where the boss drove it and said, "nuttn's wrong here", everythings within spec. He even suggested, "you're probably usta a different car if you rented a replacement." What a line!
So I saved my breath arguing and instead took it to Town Fair. They handed me a print out, showing that the toe on one of the rear wheels was off in such a way to cause the violent pull to left. I mean, I could take a left bend in the road simply by releasing the wheel! Town fair suggested that the car must have mis-mounted on the alignment rack by whoever did the work at the bodyshop.
Town Fair corrected *most* of that, but I still had to watch it on the highway. Many times I would find myself on the inside(left lane in US) inadvertantly, sometime even right in front of another driver.
Last fall, I had my rear struts replaced. 4whl alignment peformed. Again, some left pull removed, but not all.
Two weeks ago, had a front axle and the left front bearing(closest to impact in 2000 accident) replaced.
This time alignment was the best since 2000,
but I still noticed some things on my printout from May:
My caster settings are at the most negative(more upright) of the "specified range", my front wheels are toed out to the most negative (front edges outward) of it's range, and my camber, f&r, is at the most negative end(tops leaning in) of it's range. Total thrust angle is -0.01degrees acc. to the print out, which has to be some fraction of a degree to the left, but not enough to matter.
My shop does struts, so there's no excuse that they "can't adjust camber/caster".
What would you folks recommend adjusting to stop this American car, on AMERICAN roads, from continuing to pull left like it's in England?
-Chris
