Posts: 202 |
wut is the bar in the front suspension that attaches to the struts and passes under the car????Sway bar??? anti-roll bar??? it has about half and inch of play from side to side and when i turn and hit a bump i here a cluncking!!! Is that causing the problem??? and can it be tightened???any help would be greatly appreciated!!!
Wht 98 Zetec Vct
2 12'MTX thunder 3000, logic 500W amp,8 interior speakers:2 sony mobile Es 6*9 250W,2 JVC 6*9 200W Sony 208W cd receiver,Streetglow blacklight interior trim
C.A.I. transgo shift kit,
Posts: 1,399 |
How is it moving. Sounds like just end links and bushings. Endlinks are a two-bolt replacement, very easy, you WILL be able to do it yourself. If the sway bar to frame bushings are gone, it's a little more difficult. Search and you will find.....
98 Silver Frost SVT
97 BMW 540I Sport, six speed
"Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future"
"A coveted car should never stunt your life, but should make it more rich and interesting."
Posts: 202 |
i think its the bushings cuz it slides left to right right throught the holes where it passes throught the frame.how much $$$ will this cost is it just the bushings that need to be replaced???is it safe to drive it like this??? and thanks for the help!!!!
Wht 98 Zetec Vct
Posts: 202 |
can i improve the handling by adding a larger bar ,like a svt sway bar???? wut kind of improvement will this add???
Wht 98 Zetec Vct
Posts: 10,015 |
All front sway bars are the same, and making the front bigger make handling worse on a FWD car anyway.
You can get replacement Polyurethane bushings for the front from SP Motorsports.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 3,867 |
The SVT front bar (18mm, IIRC) is smaller than everyone else's (20mm). Installing it would help to reduce understeer.
Combining it with an OEM rear from an SVT or early SE would help even more, without major subframe alterations.
Function before fashion.
'96 Contour SE
Posts: 9,602 |
SVT front bar is 19mm All other CDW-27's are 20mm
The smaller front bar promotes less understeer
95-97 SE & all SVT rear bars are 19mm All other CDW-27's are 16mm
The larger rear bar promotes more predictable power off oversteer.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 202 |
thx for all the help. how bad is this for the suspension as i will have to wait for the weekend to do anything and i drive alot for work will it be ok it i take it nice and easy or is it major?????
Wht 98 Zetec Vct
Posts: 3,867 |
The sway bar (on this car) is not a locating or structural member of the suspension, so I think you'd be OK in the short term.
'96 Contour SE
Posts: 9 |
Sounds like you need a new set of bushings... SPMotorSports sells Energy Suspension front sway bar bushings for like $8.
