#65752 07/10/02 05:14 AM
X
xx boy Offline OP
X
How to break a hub nut free without air impact wrench help?
A/C is down I want to hard wire the compressor
but where the wire should go?
95se
30" breaker bar for the hub nut, with whels on the ground.Ac compressor...hard wire if its not working?..confused on that one....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
95se
On the hardwire, do you mean you want to defeat the pressure switches and such that shut off the compressor when you do things such as accelerate under full throttle, or that automatically shut down the compressor if the pressure in the lines is too high or too low? (Man that was a long run-on question!)
You are basically just asking to ruin a compressor, unless of course this is just for troubleshooting, don't do it.
TB
Tony Boner
