Posts: 1,049 |
my v6 s.e. seems to have a funny rotten egg smell every once in a while someoen told me it could be the cat. the smell is simialr to well water but its comming from the car.
Posts: 2,446 |
sounds like a cat. problem to me.
Posts: 1,165 |
'01 GTP: 3.3" pulley, Headers, 3" Exhaust, Straight Pipe, Intense Air to Water Intercooler. Pictures
Old Ride: 95 Mystique LS V6 ATX: Pictures
Posts: 115 |
Originally posted by cvkillacontour98: my v6 s.e. seems to have a funny rotten egg smell every once in a while someoen told me it could be the cat. the smell is simialr to well water but its comming from the car.
O2 sensors(they are called hego when you put it on the comp.)I had the same problem,I switched my O2's out and the problem was gone
Posts: 1,049 |
Posts: 1,049 |
Posts: 667 |
Originally posted by cvkillacontour98: what is hego?
HEGO = Heated Exhaust Gas Oxygen Sensor
Basically, it is a heated O2 sensor.
There is a good article on O2 and heated O2 sensors at http://www.asashop.org/autoinc/dec2002/mech.cfm
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
Posts: 2,586 |
for the record, I have brand new o2 sensors and the smell is still there for me... would this lead to bad CAT?
97 T-Red LX ATX
pre98 CF SVT front,SVT rear/side skirts
FSVT wheels
Custom Front Ford Logo (body Colour)
35% tint all around with sun visor
WP With Metal Impeller?
Elky Grills
CTA Intake
CTA Custom Dual Exhaust
Posts: 5,810 |
You will get that smell anytime you have raw unburnt fuel going down the exhaust into your catalytic converter. Most often it happens under acceleration and it can happen with new or old cats. It just means you are running a tad rich and probably won't hurt anything as most cars will do it. If you never smelled it I would think it odd honestly though a well tuned car would minimize it.
See My Mods
Posts: 7,012 |
i must have been dumping large amounts of gas into my cat. i had the egg smell bad sometimes.
Oo (xxx)oO
o xxxxxxxx o
